Results 1 to 6 of 6
Thread: Stalling and Won't Start issues
    VT Acclaim
    Nov 2011
    Default Stalling and Won't Start issues
    Hi my beloved VT has been well looked after but with 245000 on the clock now needs a bit of extra work. Two main issues if anyone has any ideas what could be causing this pls help:
    1) appears when engine is warm sometimes (and getting worse) it turns over but does not start. Have to keep trying for a few minutes hoping battery does not go flat to get it to start. NEVER happens when engine is cold i.e. first thing in the morning after sitting all night. Sometimes when first turning the key it seems to start straight away for a split second but then just turns over with a bit of a thud. When it does decide to start it seems to splutter a bit.
    2) when driving and mainly when ease off accelerator to reduce speed, going down a hill or driving slow etc, I guess when revs are not high, car stalls and all lights on dash are on like battery was disconnected for a millisecond. Have to pull over and start car again. Now sometimes problem 1 happens when trying to restart - not good.
    Any advice appreciated.
    D.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Crank angle sensor, if it only happens when hot. Common problem.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    98 vt s pac
    Feb 2009
    Corowa NSW
    Quote Originally Posted by Hangman View Post
    this ^^^^^^^^^
    VX Commodore
    Sep 2011
    Bisbane
    Mine was cutting out almost as soon as the engine warmed up a little (Maybe after driving about 5-10km) and I replaced the coil pack and that seemed to work.
    vts 1999 V6
    Oct 2011
    Hi Commodoreluc
    did you replace the DFI + coil packs with new or second hand?
    thanks
    bones308
    '97 VT Calais
    Apr 2007
    Most likely crank angle sensor, but could be a loose battery terminal, which expands when heated.
  1. Vr v6 was stalling now won't start???
    By stan350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2011, 10:32 AM
  2. Intermittent stalling and restarting issues
    By Dannal in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2010, 08:46 PM
  3. vp v6 5 speed stalling issues
    By kitted vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2010, 10:54 PM
  4. stalling on first start
    By Berlinarator in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-03-2007, 09:43 PM
  5. Start Then Stalling
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-04-2006, 09:59 AM
