Results 1 to 3 of 3
Thread: Brakes going soft and handbrake light go on in 1999 vt wagon
    VT Acclaim
    Nov 2011
    Taringa
    Default Brakes going soft and handbrake light go on in 1999 vt wagon
    Hi all,
    Its happened to me twice now. If I sit in traffic for to long my brakes go soft and the handbrake light comes on, feeling as if the handbrake is on slightly. Also once this happens it makes a clunking noise in the back if you take off from stand still.
    If i turn the car off for around a minute or 2 the problem goes away..
    Any ideas?
    vt commodore s1
    Aug 2011
    sydney
    wow exactly the same happened to me!!! do a brake fluid flush and bleed!! also check all your brake pads!! i replaced the master cylinder while i was at it with a brand new one! feels really good now!! but what it is, is that the fluid gets boiled when gets too hot and you loose pressure in the system! hope that helps!
    VT Acclaim S/W 1999 V6 & VX 2002 x police sedan
    Feb 2010
    south/ eastern qld
    I'll be checking the brake vaccum boost assist for leaks!! include the hoses as well.
  1. soft brakes on 2004 vy s pac ute with abs
    By turbo ute in forum General
    Last Post: 23-08-2011, 06:22 AM
  2. 1999 VT Wagon Handbrake
    By vsute97 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2011, 11:40 PM
  3. brakes stuck on due to handbrake
    By Zort58 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-01-2011, 09:11 PM
  4. Changed brakes now brake peddal too soft cant break..help???
    By Dragz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-04-2009, 12:28 AM
  5. vn wagon handbrake
    By radiohead in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2006, 04:21 PM
