Results 1 to 7 of 7
Thread: Fan not working
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default Fan not working
    One of the fan in my wh caprice is not working. I had my ac on full blast but still one fan working.
    VY SS
    May 2011
    Auckland
    Was the engine at temperature? Usually one fan is ac and one is to cool radiator when it heats up due to low airflow
    Jul 2011
    saudi arabia
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Disconnect the fan and then connect 12 volts directly to the fan wiring and see if it works, just connect it directly to you battery with some wire. If it works then your problem is elsewhere, if it doesn't work then the motor is stuffed.
    MY RIDE
    Jul 2011
    saudi arabia
    Jul 2011
    saudi arabia
    I connected the fan to the battery and it worked. Then I checked the plug of the fan and two pins were loose. I reinserted them and it works now. Thanks for the help.
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    Quote Originally Posted by m1lky View Post
    Gee mate you only have one work.....both mine come on either when you turn a/c on or temp goes over 98.....if temp gets to 104 both kick up a notch........maybe they changed after the VX?
  1. thermo fan working..but not working!
    By nalchlan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2011, 12:19 AM
  2. Replies: 2
    Last Post: 07-10-2009, 02:40 PM
  3. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  4. new hu not working
    By orbisfactor in forum Car Audio
    Last Post: 07-02-2008, 03:58 PM
  5. Fan not working on VN
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2006, 01:20 AM
