Results 1 to 7 of 7
Thread: Gearbox problem from top gear (auto)
    1998 VT Acclaim
    May 2010
    Default Gearbox problem from top gear (auto)
    Hi all, got a problem with my 99 vt Acclaim.
    Gearbox changing is fine up to top in the auto, however if or when you accelerate from 50 or more 70kms a full on shunting starts like its missing but when you change down to 3rd all fine and dandy back up to top and smooth sailing till the next pass etc.
    Is it the bands? Sensor? No warning light comes on at all.
    Any ideas would be a big help.
    Thanks
    BJ
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Spark plugs or leads are usually the cause of a miss under load, leads more often than plugs.
    MY RIDE
    1998 VT Acclaim
    May 2010
    thanks for the reply,
    if it is either leads or plugs, why only in top gear?
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    Quote Originally Posted by Artic View Post
    Top gear would have more load than 1,2,3
    vx v6 comodore
    Jan 2011
    sunshine coast
    Had the same problem, It was a bad Spark Plug.
    Only ever missed under load, Ie 4th/overdrive
    Good Luck!
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    I agree,almost certainly plugs and leads but just possibly could also be a coil pack.I've mentioned previously on this forum that I never cease to be amazed just how sensitive these gearboxes are to engine tuning.My gearbox was supposedly RS about 60,000km ago when I needed plugs and leads and more recently I noticed the 3/4 gear changes were a bit ordinary again ,only to discover that the coil pack needed replacing.Good luck
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    I had a similar problem in overdrive/4th it would go on and off the throttle by itself (thats what it felt like) at certain low revs and would go away if I gave it slightly more throttle. The Auto let go shortly after a couple of weeks later in spectacular fashion lol
    New rebuilt auto doesn't do it
    ========My Statesman 20's Mafless and 3.9's========
  1. VT auto gearbox, will not shift into gear, like in neutral
    By ka1sa226 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2011, 03:43 PM
  2. VE auto gearbox problem
    By JennM82 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-12-2010, 08:33 PM
  3. Auto Gearbox sometimes only allows take off in second gear.
    By VTSSDUDE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-12-2010, 05:57 PM
  4. VE SS auto gear changes problem
    By Homer's HSV in forum VE Holden Commodore (2006 - ?)
    Last Post: 16-03-2010, 08:48 PM
  5. VK Auto GearBox Problem.
    By garysholden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-03-2009, 11:41 AM
