Results 1 to 2 of 2
Thread: Oil in water or trans fluid in water?
    VT S2 Wagon
    Nov 2011
    SA
    Default Oil in water or trans fluid in water?
    Brown sludge under the rad cap slightly white. Rad has just started leaking badly so could it be trans fluid getting into the water or would it be intake mani gasket or head gasket still?
    vn executive series 1 v6 1989
    Sep 2011
    maryborough
    when i got my car it has trans fluid in the water cause the inside of the radiator was eaten out had to flush the motor like 3 times to get it all out and leave the transmition pan off over night to drain put a new radiator in filled it up and its all good... it was a kind of whitey pinky coloured blobs of tans fluid in the water
  1. idiot put water in power steering fluid
    By Mumof4boys11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2011, 01:48 AM
  2. Mysterious water leak. (water drips from bonnet lever?!?)
    By theragert in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-03-2011, 08:39 PM
  3. vrvs sedan water found in boot how i tested to find where the water was leaking from
    By peter1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2011, 08:49 PM
  4. Water in oil and leaking trans And vn s1 motor into vp s2
    By v6vpute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2010, 05:28 PM
  5. Water in with the trans fluid!
    By JD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2007, 07:35 PM
