Results 1 to 2 of 2
Thread: Engine Oil
    Commodore
    Feb 2010
    Default Engine Oil
    My VX Berlina has done 120k kms and lookin at doing a service wondering what brand oil you use and the grade oil is
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    I would suggest you check your owners manual as the recommended oil grade to use... but I believe the "Holden" recommended brand/grade is:-
    ENGINE LUBRICATION
    2.1 ENGINE OIL VISCOSITY AND CLASSIFICATION RECOMMENDATIONS
    For VX Series models fitted with V6 engines and LPG, engine oil to Holden Specification HN2314 must be used.
    The specified oil classifications are as follows:
    BP Vanellus C3 15W/40 SH CG4
    Mobil LPG Oil 15W/40 SH CG4
    GEN III V8 engines, use Mobil Full Synthetic 10W/30 engine oil for general use and high ambient temperatures.
    All of my cars use Castrol 10W/50, non synthetic, mineral oil every 5k/6Months + Filters religiously... In the end the type/brand of oil does not really matter too much, it's the number of Km's over how often you change the oil/filters. If you're lazy and/or have to pay someone to service your pride and joy... I would go for the best I could/can afford.
  1. missing engine cover bolts 5 litre engine
    By justice4all3000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2011, 06:17 PM
  2. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  3. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  4. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  5. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
