Results 1 to 16 of 16
Thread: clutch goes to the floor
    Commodore M6
    Jul 2010
    East Coast
    Default clutch goes to the floor
    this is a weird one
    car was driving fine yesterday and now the clutch goes to the floor and gearstick moves but no engagement
    sounds like hydraulic slave or clutch cable or whatever this is?
    VTII Calais 5.7
    Jun 2010
    Hydraulic clutch? Master/slave cylinder, or the line between the two. This happened on my car, and the master cylinder had exploded and sent fluid everywhere, pedal went straight to the floor.
    Master cylinder is not too hard to get at... A 6 speed slave cylinder however is a bad thing.
    VY SS
    May 2011
    Auckland
    VE International 3.6L
    Jun 2011
    Gold Coast.
    You'll need to know how to get it moving from zero now, and double de clutch to change gears.
    Commodore M6
    Jul 2010
    East Coast
    yeah reservoir is empty
    i'm hoping it just needs a bleed and fluid top up
    i find it strange its working fine one day and dead the next
    VX SS commodore
    Dec 2011
    Blue Mountains
    So what ended up being the problem.. My vx cluth is intermittantly going to the floor.. Not losing fluid and master cylinder has been changed.
    no apparent leaks.. If the slave was shot, wouldnt i be losing fluid??
    VY SS
    May 2011
    Auckland
    Intermittent sounds like there could be a very small amount of air in the system. Try bleeding it again
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    It's common for the slave cylinder to let go on V8 6 speed manual Commodores, we just done a VY SS at work not long ago, need to remove the whole gearbox to replace it.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    Commodore M6
    Jul 2010
    East Coast
    i ended up putting a new clutch in as well... damn that wasn't cheap
    stupid car
    VX SS commodore
    Dec 2011
    Blue Mountains
    Where abouts on the box is the bleeder? When the mster cyclinder was replaced, the guy that did it tells me that ïts self bleeding".
    worked ok for the first 1500 klms but is now getting worse..
    I have only worked on cable ones and carnt afford to take it to a mechanic..
    Any advise greatly appriciated..
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by aviationmush View Post
    Bleeder isnt on the "box",its on the actuators body.
    Change your grease monkey,its not a self bleeding system..Hope these pics help you out..
    Attached Thumbnails Attached Thumbnails clutch goes to the floor-01-dec.-30-23.39.jpg   clutch goes to the floor-02-dec.-30-23.39.jpg   clutch goes to the floor-03-dec.-30-23.40.jpg
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Wrong diagram. The clutch slave cylinder is within the gearbox bell housing and is a bugger to bleed. Below is the correct diagram. Before you try and bleed it, install the Xtreme extended clutch bleeder. I purchased mine for less than $20 at Bursons. It makes bleeding the clutch a breeze. You need a long 7/16" socket and a short thin socket handle to remove the old bleeder (space is very restricted). Line the inside of the socket with masking tape or packing tape so that the old bleeder sticks to the socket and doesn't fall into the housing. Check out the web site below for details of the bleeder. If you need more details send me a PM.
    http://www.xtremeclutch.com.au/page.asp?parentid=4&parent2id=25&productid=32
    Attached Thumbnails Attached Thumbnails clutch goes to the floor-v8-ls1-clutch-control-layout.jpg
    VX SS commodore
    Dec 2011
    Blue Mountains
    This isnt fun anymore... Turns out the slave at packed it in.. Mate and i pulled the box out, replaced the slave and fitted new clutch kit for good luck. Put it all back together, bled the clutch, all good. Within 100klms city driving, soft again. As no loss of fluid, bled again. All good. Now have put about 800klm's on it and the damn thing is intermitantly losing pressure again.. Have checked all lines and connections.. no leaks. The car was nose up when it was bled, Should i have it on a hoist level to ensure i get all the air out ??. This is driving me crazy as i am not game to let the minister for war and finance drive it in case it fails.. I have to be doing something wrong.. Suggestions anyone??
    VY SS
    May 2011
    Auckland
  15. #15
    VX SS commodore
    Dec 2011
    Blue Mountains
    Master cylinder is brand new as well.. Was the first thing replaced when this capper started happening...
  16. #16
    Aug 2004
    Once you have lost all your fluid it takes a couple of bleeds before you get all the air out of the system - particularly out of the master cylinder. Try bleeding again, then repeat a couple of weeks later. Should be OK then.
  1. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  2. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  3. wet floor
    By Milesvess in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-05-2010, 09:00 PM
  4. [VIC] WTB T5 clutch fork cover, floor plate boot etc...
    By Vlad01 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-02-2010, 06:01 PM
  5. sub in un-even floor in vs
    By crainy in forum Car Audio
    Last Post: 13-08-2005, 07:02 PM
