Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By m1lky
Thread: Pulled off heads and gaskets dont seem to be blown? Help
    VT S2 Wagon
    Nov 2011
    SA
    Default Pulled off heads and gaskets dont seem to be blown? Help
    Oils been getting into the water and also loosing coolant somewhere (no water in oil though)
    Pulled off heads and the gaskets just look eaten away? Is that normal? Also the holes for the water galleries are pretty much blocked with this eaten away gasket. Help!
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    VT S2 Wagon
    Nov 2011
    SA
    hakhawk's Avatar
    Jan 2005
    VT S2 Wagon
    Nov 2011
    SA
    they looked like brand new. do you reckon it could have been from wrong coolant eating away at gasket?
    VT V6 Manual
    Apr 2009
    Whats with the brown stuff? Looks like water has been used instead of coolant and there's been rusting going on. Thats not healthy for any of the parts.
    VY SS
    May 2011
    Auckland
    Before you put it back get the head checked to make sure it isn't cracked or warped.
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    why didnt you just compression test the engine before removing the heads?
    now you have the engine in peices you may aswell get another engine, cheaper to fix and your problem is solved
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Get The Heads Inspected Mate, if they are ok, then clean the heads and block, then Replace the Head & Inlet Manifold Gaskets. Flush the whole system out. That should solve your problem champ. and replace anything else that looks worn while your there. all well and good just to get another engine but for all you know it could be worse !
  1. heads gaskets replacement
    By coca in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-09-2011, 09:48 PM
  2. 2000 wh s/c v6- blown head gaskets
    By Skitzo-666 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2011, 10:39 AM
  3. Head light globes blown or fuses blown?
    By SteveHatz in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-05-2011, 11:53 PM
  4. Pulled heads off 304, and...
    By jimmyd17 in forum V8 Development and Modification
    Last Post: 11-02-2010, 10:12 AM
  5. commodore heads blown
    By nielsonp in forum General
    Last Post: 25-08-2009, 08:20 PM
