Results 1 to 9 of 9
Thread: Spring vs Screw clamps?
    VT V6 Acclaim
    Nov 2008
    Default Spring vs Screw clamps?
    Hi, what is better spring vs screw clamps, I currently have spring clamps but I got some screw clamps for free with my hoses.
    Also there is a tool to make removing the spring clamps easy but repco couldn't find it for me, anyone have some info on this too?
    it would make removing the bottom hose easy.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Spring clamps are the work of the devil I say. Seriously removing the heater tap clamps with pliers are 8pm just to get home is a real bitch. Now it has screw clamps.
    Ronald Reagan (1986)
    VY SS
    May 2011
    Auckland
    VYMAD's Avatar
    VYMAD is online now SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Yep, get rid of the spring clamps, they are CRAP!!!! Not only do they not tighten as well as screw clamps, but over time they seem to 'cut' into the hose, whereas screw clamps' pressure is distributed over a wider area, like 5-10mm, as opposed to 2mm of wire. And the best tool for removing them is multi grips, like said above. You definately don't need to buy a special tool!
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I prefer screw clamps for the reasons stated in the above post^^^.
    I find that when you remove a spring clamp and don't put it back on exactly the way it was before, you will often get a leak.
    MY RIDE
    VT V6 Acclaim
    Nov 2008
    Interesting, I seriously thought everyone preferred spring type ones because they don't tighten too much and brake your plastic or whatever outlets. Good info I'll change them over to screw type. Thanks
    VY SS
    May 2011
    Auckland
    I can see why the factory uses spring ones though. Much quicker.
    With polygrips they're easy to get off. I don't plan to change mine
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by Orpheus View Post
    dont be heavy handed and you wont break any plastic
    VT V6 Acclaim
    Nov 2008
    I can get them all of easy with needle noise pliers but the bottom one is a complete bitch, I hate it
    If it wasnt for the one they would be way faster there screw one. but as someone said they do look like they can cut into the hose
  1. Spring clamps neededh
    By braddz93 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-05-2010, 12:20 PM
  2. Spring Clamps
    By Robbo VS3 in forum General
    Last Post: 13-11-2009, 01:57 PM
  3. [VIC] t bolt clamps
    By jaisvz in forum Swap / Wanted to Buy / Trade
    Last Post: 29-09-2009, 01:32 PM
  4. Radiator Hose Clamps..
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2005, 08:29 AM
  5. Spring Steel Radiator Clamps...
    Last Post: 05-12-2005, 05:38 PM
