Results 1 to 4 of 4
Thread: VX air conditioning clutch not engaging.
    VX
    Nov 2011
    Pukekohe NZ
    Default VX air conditioning clutch not engaging.
    I recently degreased and washed out the engine bay on our 3.8 VX. On starting the car later in the day, the A/C didn't work.
    A/C light on the inside button comes on as it should.
    Compressor clutch has no voltage to it, even with pressure switch bridged.
    A/C radiator fan also isn't going. but does when pressure switch is bridged.
    No engine rpm increase. but does when pressure switch is bridged.
    I've open and sprayed out as many plugs in the local area as I can find.
    Standard wiggling of plugs and looms while the engines running has no effect.
    I assumed it was a gassing issue. After system was gassed, the fault remained.
    I'm out of idea's. It seems that there should be a blown fuse somewhere?
    99 VT 3.8 ECOTEC
    Jun 2011
    ive got this same problem in my 99 v.t, the car was at airport parking in brizzie for 3 weeks. same issues, light comes on... no rpm increase... if you find an answer let me know. msg me thanks mate. its summer and i need this fixed,
    1999 HOLDEN COMMODORE VT 3.8 ECOTEC
    BASICALLY STOCK EXCEPT EXHAUST, GO THE NOISE!
    http://imageshack.us/photo/my-images/51/img0383oh.jpg
    vl
    Apr 2011
    brisbane
    I would be checking the relays next, perhaps swap it over, they are clearly labelled. hope this helps
    VX
    Nov 2011
    Pukekohe NZ
    Thanks for the replies, have swapped around the horn and A/C relays with no change. A/c relay works fine in horn slot.
  1. VS V6 Air Conditioning Clutch Bearing P/N° Please
    By c172skyhawk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2010, 02:33 PM
  2. help air con not engaging.
    By thepowerman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2010, 11:25 AM
  3. Part No. for VP V6 air conditioning clutch bearing
    By sossposs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-01-2010, 04:48 PM
  4. VT V6 - Air conditioning clutch won't energise
    By Darren D in forum Electrical Wiring / Questions
    Last Post: 07-10-2009, 02:27 AM
  5. Cooling fan not engaging
    By Wynnie88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 11:07 PM
