On my caprice both fans start at same time even with the ac off. One fan should start first then the other, am I correct? How do I fix it.
Both fans should come on together, first at low speed and then on high if the temperature reaches 104 degrees.
MY RIDE
According to my manual, if you turn the A/C on both fans should come at low speed, which mine do. They also both come on at low speed without the A/C once a certain temperature is reached. If the temp reaches 104 degrees both fans will operate on high speed. Mine doesn't get that hot because I don't think I've heard them on high speed.
MY RIDE
