Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By edals
Thread: delay in acceleration with foot right down
    VX Berlina II
    Sep 2011
    Unhappy delay in acceleration with foot right down
    Hey i've had my car VX Berlina II 3.8 auto for a month now and if i ever put my foot right down to the floor or close to it you dont feel the acceleration kick in for a second or two whether ur going 60 k's or 20 k's or stand still it makes no difference, as this is my first car im not entirely sure if this is meant to happen or not, if Not then what could be causing this? would be nice to have it alot more responsive when you want to pick up speed fast?
    vr wagon
    Aug 2010
    vic
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    sounds normal, you dont have a supercar.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    Commodore M6
    Jul 2010
    East Coast
    can you tune the ecu with a memcal or some shit to make throttle response better?
    VX Exec M5
    Alien Invasion 2 Champion! Gyro Ball Champion!
    Apr 2010
    Melbourne, Bundoora
    Mine doesn't delay that much, maybe half a second or so at the most, but mine's a manual.
    None of us are as cruel as All of us. - Anonymous
    VY Clubsport R8
    Sep 2010
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Yep Its normal, about half a second or so. bugs me too but what can ya do, they are family cars not race cars lol
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    Quote Originally Posted by edals View Post
    Plenty, but it's gonna cost you. I managed to remove the horrid flat spot for the most part. Gearbox needs some work though.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Kulwinder is offline Kulwinder
    VX Acclaim Wagon
    Nov 2011
    St Albans
    drive another commodore.
    if same, then it is just transmission, takes time to shift gears. its normal.
    if different, check throttle body or vaccume . may be sucking air from somewhere just before fuel.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    I found what can help is a exhaust system. The VX has a hiflow exhaust, has removed it some, the VY has stock its more noticed. but the VX was the same before i changed over the exhaust
    VX Berlina II
    Sep 2011
    ah yea, well i am looking at getting a new exhaust sometime soon, probably the 2.5 redback catback with twin tip even tho im on my p's what are the chances of getting pulled up for it? lol they arent real loud are they?
    holden vt commodore
    Oct 2011
    hey mate
    my vt recently was doing that for a while until the other week
    when it started overheating because my radiator had a crack
    now i asked the mechanic about the delay and he said
    that when the engine i running hot it culd cause the transmission wall to heat up which causes a delay
    so some advice is to check to see if your car is running hot.
    before ya head gasket blows i got really lucky that i had no damage
    VX Berlina II
    Sep 2011
    Quote Originally Posted by Potto View Post
    hey mate
    Hey, i dont think its overheating as the temp gauge never goes above half way? about a month ago a mechanic said my trans fluid was a bit discoloured and is due for a flush i dont know if this would cause anything like delay?
    Sasha_85's Avatar
    Sasha_85 is offline My VTEC ate your V8 ;-)
    Type R Integra, VE SV6, L67 VS
    Nov 2011
    North Brisbane
    i aggree with the others saying its just a commodore thing ..
    you gotta take weight of the car into consideration ..
    i have a Type R Integra with 162fwkw at 980kg and its the most responsive thing running 12's ..
    my VT took awhile to engage in response like said , family car not race car, 1.7 tonne car with only 147kw at fly or whatever they are ..
    KONY puts the meaning of "INFANT" to "INFANTRY"
  15. #15
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    The responsiveness (or lack thereof) in this instance has little to do with the weight of the car and everything to do with the electronic control of the transmission. My (standard) VN and VP V8s were magnificent in terms of changing gears quickly via kickdown. My VS Calais V8, by comparison, was very leisurely in changing gears via kickdown, and it was only after installing a shift kit and a host of other changes that I now have the sort of transmission that changes as fast as I want, up and down.
  16. #16
    VX Executive
    Feb 2008
    Have you looked at your throttle cable? maybe its loose and doesnt open up the valve in the throttle body in fast response to your gas pedal
  17. #17
    Aug 2004
    Quote Originally Posted by blacknight View Post
    You need to have the throttle cable fairly loose on a Holden V8 otherwise it makes the idle speed too high.
  18. #18
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    My Calais was like that, and is very normal. I jumped into a BA falcon after driving mine, and the responsiveness was 10 fold better.
    Quote Originally Posted by Dv8eD View Post
    Does anyone know how to pop the reverse sensor back into its spot without removing the rear bumper?
    Quote Originally Posted by Rufys View Post
    1. Remove the rest of the car from the rear bumper. Pop the sensor back into place. Re-attach the car to the bumper. Personally, I reckon it would be easier to remove the rear bumper.
  19. #19
    VT Wagon - Stock
    Nov 2011
    Warrnambool
    yeah sounds normal to me, id only start to worry if it was any longer than that
  20. #20
    Vt 3.6 Acclaim
    Feb 2012
    NSW
    I agree, its a commodore thing , the engine response annoyed me enough to buy a 2.5 " 'redback' catback exhaust, A '3A' pod which has been modded to my factory airbox, and i checked the throttle cable, which needed to be tightened. Response is better, but i'm still buying a high flow catalytic converter and getting it installed.
  21. #21
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Quote Originally Posted by Kieran263 View Post
    Lmao!!!
    What are you on about! You don't have an automatic trans so it doesn't kick back gears
    And you shouldn't have any delays being manual!
    =S
  22. #22
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by daNc View Post
    my car VX Berlina II 3.8 autos
    You have answered your own question, it's a family V6 automatic - not a S'Charged V8.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
  23. #23
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    My 2 cents, if you want better response, buy a VN-VR with a buick motor, my vn had insane throttle response, auto let it down a bit though
    Check out my VT BERLINA WAGON
  1. jerky acceleration when i put my foot down
    By comfortablynumb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2012, 08:36 AM
  2. yet another delay!!!
    By turks 74 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-03-2011, 09:49 PM
  3. VZ Headlight delay
    By thunder-60 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-05-2010, 09:34 PM
  4. Acceleration Delay
    By Chris92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-05-2010, 01:46 AM
  5. Delay on accelerating
    By bigal in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-04-2010, 10:21 AM
