Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By ozdash
Thread: Ecotec - Where else can oil get into water if not blown head gasket?
    VT S2 Wagon
    Nov 2011
    SA
    Default Ecotec - Where else can oil get into water if not blown head gasket?
    Oil is getting into water and its not a head gasket by the looks of it. Help...
    99 VT Series 1 Wagon
    Nov 2010
    the valley matey
    Never approach a goat from the front , a horse from the rear or a fool from any direction
    VT S2 Wagon
    Nov 2011
    SA
    mmm makes sence too. the intake mani gaskets and valleys look newish maybe they didnt seal it good enough in the corners?
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Vx2 Calais 5.7
    Jul 2011
    Tightening won't work the side gasket get old and brittle and will crack if u try an tighten the bolts just replace them
    VT S2 Wagon
    Nov 2011
    SA
    heads are off atm putting it all back together with a vrs kit tonight. the intake mani bolts were suprisingly loose when i took it off though. Like i used a little 1/4 ratchet with one hand to undo them all.
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    when the mechanic did mine on my old 5L he had to do a retension after a heatup cooldown cycle
    ========My Statesman 20's Mafless and 3.9's========
  1. Engine leaking water, blown head gasket?
    By phatvtcom in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2010, 12:59 PM
  2. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  3. How To Tell IF a Head GAsket Is Blown?help
    By damotheking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2007, 08:42 PM
  4. think ive blown a head gasket
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2006, 12:10 AM
  5. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
