Results 1 to 6 of 6
Thread: engine light vx ss
    vx ss
    Oct 2011
    Default engine light vx ss
    I've got a vx ss auto done 150 on the clock got full trans service cause engine light was coming on so I thought I would get that done but still comes in only reason I thought it was the trans was in the manual it says that It is either trans or electrical there is no difference when driving it just wondering if this is the case with others and if so did anyone fix it? The only was I turn the light off is, turn the car off turn then to the on position then do I again then turn the car back on whilst driving that the only way it goes away
    Vx ss
    May 2011
    Nsw
    Take it to mechanic to check what codes it throwing up could just b a sensor I have same car engine light came on a couple weeks back found out it was my knock sensors
    vx ss
    Oct 2011
    Do they just hook it up the the computer or something? How much was it for a knock sensor and were is it? Can I do it at home? I do most of my mechanical stuff my self eg water pump alternator and services etc is it hard to do ur self or do I need a mechanic to do it?
    Vx ss
    May 2011
    Nsw
    Yeah they just plug scanner into computer and bang tells them prob there and then,, and yes knock sensor is easy fix at home just take of inlet manifold and there under there,, u have to be careful of wire loom get fragile from the heat sensors around 100 each depending where u get them from
    Vx ss
    May 2011
    Nsw
    vx ss
    Oct 2011
    Thanks for that I'll have to take it to someone and see what it comes up with thanks for ur help I'll let u know what it comes up with
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  5. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
