Results 1 to 8 of 8
Thread: vt getrag sloppy shifts
    vt s pack manual
    May 2009
    gawler, adelaide
    Default vt getrag sloppy shifts
    hey guys, got a manual vt s pack not long ago, ive notice the shifts are pretty sloppy, in gear theres alot of movement avalible from the shifter, ive asked around heaps of places, a few auto parts stores and about 5 gearbox places and no one knows anything about them, now as far as i know the getrag uses linkages so the linkage bushes would be past if its sloppy yes ? does anyone know what i can do about this ?
    If you're not driving a manual, you are only steering, not driving
    tim005's Avatar
    tim005 is offline Yet Another VS Ute Owner
    99' Series 3 VS S-Pac Ute.
    Feb 2009
    Melbourne.
    Gertrag's are known for being sloppy mate, it's just a common thing.
    My gears have a lot of free play too..
    http://forums.justcommodores.com.au/...first-car.html My VS Ute, 99', S Pac, 5 Speed.
    Quote Originally Posted by maldotcom2 View Post
    Also, always go into a corner in second gear in case you see a hot chick or another commodore you can fang it out sideways.
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    yes getrag boxes are sloppy.
    feels like a spoon in the cake mix trying to select gears =P
    you can change the bush/bushes (i dont know the amount) in there.
    someone else could answer this.
    also not sure but could getting a short shifter tighten it up more?
    or do they go sloppy after a while aswell?
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    vt s pack manual
    May 2009
    gawler, adelaide
    i had a short shifter in the vp and it would make the throws shorter but it would still be sloppy i recon. i wouldnt have though it would be like this, its a shit gearbox lol i could put a t5 in it with the hydrolic set up in it, that'd be wicked!
    VT V6 Manual
    Apr 2009
    I got rejected for roadworthy because of mine being sloppy.
    I had a circlip missing from the gearshift. Had that replaced and it was a tiny bit better, but still there is movement when in gear.
    The rwc tester said the bushes needed replacing (but passed it because the circlip relacement made it a bit better).
    The mechanic says even with a new linkage it would never be completely tight, its just the way they are.
    There are apparently 2 bushes, one on the gearbox side and one above the linkage?? I cant remember specifically where the mechanic said, but he told me its something you do when you have to do a job on the gearbox. ie leave it alone until you have to go poking around in there.
    vt s pack manual
    May 2009
    gawler, adelaide
    thats intresting, it may need a clutch soon anyway ( fkn hope not tho) and if i do ill do the bush's than.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by E-T-H-A-N View Post
    You r not alone :-) Mine's the same but use to it now.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I have discovered recently the rubber mount that holds the shift plate to the body can break and make it even worse. Maybe have a quick poke underneath and check it out.
    Mine has a short shifter in it and its much better than the stock shifter.
    Another problem I have had is the shift plate came very close to snapping. Had it welded up and its going ok now.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
  1. sloppy performance
    By koztek55 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2011, 11:46 AM
  2. sloppy shifter holden vt 5l senator
    By canabl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2009, 08:15 PM
  3. 30mm socket a sloppy fit diff fill bolt?
    By f_vos in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-04-2009, 01:37 PM
  4. sloppy shifter getrag
    By vs hay hauler in forum VR - VS
    Last Post: 10-04-2007, 11:58 PM
  5. Better manual shifts?
    By maveriick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 03:07 PM
