Results 1 to 8 of 8
Thread: Engine covered in dirt
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default Engine covered in dirt
    How do I remove the dirt and grease on my engine. It is covered with lots of sand and grease. I removed it with my finger and it seems to come out. Can I take a air compressor and blast it away. I think it will work.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If it were me I would use degreaser and hose it off, but there is a chance water will cause problems but it will eventually dry out and be fine. Avoid getting water in the alternator. Also avoid getting degreaser on the exterior paintwork (depending on the particular degreaser)
    I've degreased many an engine, usually without a problem. Degreaser works better on a warm (not hot) engine.
    MY RIDE
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Yep, agree with accentstencil.
    I'd get a heavy duty/automotive degreaser, you need something with a bit of kick. I recommend covering the alternator/coil pack with plastic bags, just as a precaution. Spray generously on the engine and allow to sit for around 5mins, scrub with an old toothbrush or brush to get in and around plenum/runners if you want and then hose off. Most people recommend then turning the engine on and allowing it to run for at least 5-10mins to help cook off the water.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Just go to the do it yourself carwashes and use the degreaser from the gun then the high pressure rinse. That way you dont mess up your own driveway.
    Go for a decent drive afterwards to dry it off.
    Silver Certified.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    I suggest you DON'T use a high pressure spray, in my experience it's a recipe for disaster. Never had a problem using a garden hose. The only time I have used a pressure sprayer it resulted in a blown coil. High pressure water droplets and electrical connections are not friends. I know some people recommend using a high pressure spray, but better safe than sorry.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    High pressure spray doesnt kill coils, its the water getting into a coil thats already cracked that kills it.
    I pressure clean engines all day every day and have no issues. Just a little common sense and not drowning electrical components is all thats needed.
    Silver Certified.
    vx v6 comodore
    Jan 2011
    sunshine coast
    Yeh a compressor wont help for grease and stuff, As stated, degreaser.
    The Export degreaser from supercheap auto is what i normaly use and its cheap, Think like $2.20rrp
    I usualy start the car and run for like 20sec just to warm it up a tad, Then hose the engine to get it all wet,(not elec) Then leave it for like 3 mins then start with the degreaser, Get it all over except alt-coil-fusebox and any elec plugs, I also do under the car, Over PS rack, Sump, Trans. Ect.
    The first time you may have to do it 3-4 times to get thrugh the oily $hit, also use a brush.
    Do it every time you do a service and you will always have a nice clean engine.
    But after that just 1 can every service will do the trick!
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Just pressure wash it. Leave it running and don't hit the fan with the end of the blaster thing. Never failed yet after doing it hundreds of times.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  1. Both my o2 sensors were covered in white...
    By nathanVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2010, 06:42 PM
  2. Isn't that supposed to be covered with something?
    By GetToDaChopa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 07:24 PM
  3. VE SS Rims, Am I covered?
    By Go_Slow in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-11-2008, 03:06 PM
  4. Camo Covered Coppers
    By Grennan in forum The Pub
    Last Post: 08-04-2008, 04:07 PM
  5. Replies: 0
    Last Post: 05-08-2004, 09:50 AM
