Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By accentstencil
Thread: dead spot in accelerator can this be adjusted?
    VX Berlina II
    Sep 2011
    Default dead spot in accelerator can this be adjusted?
    Hey, on my VX i can push the pedal down an inch or a bit less and it wont do anything, wondering this is normal and if not, can it be readjusted? also when i have to brake i cant just roll my heel i have to actually move my leg back and then put my foot on the brake because the brake pedal comes out more then the accelerator, can this also be fixed?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You can adjust the throttle cable where it connects to the bracket on the throttle body.
    MY RIDE
    VX Berlina II
    Sep 2011
    Quote Originally Posted by accentstencil View Post
    Ok thanks, i wouldnt have a clue how to do that and is this fix for the dead spot or does this bring the pedal back a bit for easier braking, and im guessing its not normal how it is at the moment? thanks
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by daNc View Post
    Hopefully both. If you look at the bracket where the throttle cable connects to the throttle body (in the engine bay not the accelerator end) you will see that it is threaded where the inner cable goes through. Undo the nuts and adjust to increase the tension, if you go to far you will increase the idle, so be careful
    MY RIDE
    VX Berlina II
    Sep 2011
    thanks for the help accent, also u were helping me a while back about how my windows fog up and said about the AC drain hose being blocked maybe, i would like to check this but dont really know what im looking for, do you get to it from the top of the car or the bottom? im not sure what im looking at/for, thanks again
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You get at it from underneath the car, above the front of the transmission. You are looking for a short piece of hose coming out of the floor, a bit more towards the passenger's side if I recall correctly, it will be easier to see with a torch. When you find it, stick something like a long cable tie up that hose to clear any debris. If it was blocked water should run out. Avoid sticking any sharp objects up there.
    MY RIDE
    VX Berlina II
    Sep 2011
    ok im not exactly sure where the transmission is lol, im only new with cars and would a pen be long enough to stick in there?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The big thing bolted to the rear of the engine is the transmission.
    You are looking a the area just behind the cigarette lighter socket in the console but from underneath the car, sort of in line with the front of the front doors. You have the flat area of the floor, driver and passenger side and in between that you have the have a space where the transmission sits. Look in there.
    MY RIDE
    VX Berlina II
    Sep 2011
    Ok thanks, very helpful hopefully i get a chance to check it later today
  1. can the tension be adjusted on the accelerator pedal?
    By Berlinarator in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-10-2010, 05:04 PM
  2. VT has dead spot
    By phyco55 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 07:14 PM
  3. vr ss dead spot ?
    By MattyVRss in forum V8 Development and Modification
    Last Post: 03-03-2009, 08:37 AM
  4. Dead spot in throttle
    By jeff62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 10:56 PM
  5. 202 dead spot
    By bowie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2006, 02:15 PM
