Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: CAS sensor ok, changed Ignition module board. Car still stalls without warning!
    VX Executive
    Feb 2008
    Default CAS sensor ok, changed Ignition module board. Car still stalls without warning!
    I had taken the car out from the shop bout two days ago and the component that needs to be changed was the Ignition module board. It looks like a flat plastic panel with a cigarette pack shaped module. Car tested was running smooth with no hesitation in acceleration, power etc.
    On the way home tonight, the car showed EXACTLY the same symptoms before cutting out in the middle of traffic. Battery warning light came on, no throttle, lights dimmed and total loss to steering. I managed to steer the car under its remaining power, waited for a few minutes and then she restarted again with no drama. I thought the issue was fixed and i'm paranoid of driving, if this car cuts power in the middle of traffic again.
    I checked the forum and there seems to multiple avenues and things to check. But if i had already checked the CAS sensor and the Ignition module board has been changed, what other items can cause the car to fail without warning??
    Please help
    99 VT Series 1 Wagon
    Nov 2010
    Have you checked the Fault codes?
    Never approach a goat from the front , a horse from the rear or a fool from any direction
    vts 1999 V6
    Oct 2011
    Hi
    see my thread
    i have the same problem
    last week Ive change the DFI module (not the coil packs which will be the next on the list)
    its been 11 days and seems OK but I'm still waiting for a hot day ,that when she seems to break down
    bones308
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sometimes the CAS will do exactly that without throwing a code. I would replace it anyway.
    Visit my Facebook page
    VX Executive
    Feb 2008
    The tech came up with no codes. so far from what i can see (and check) i have the following options.
    1. Massage the wiring looms while the car is running, if it stalls then maybe i have a corroded wire?
    2. Checked battery terminals, all ok battery voltage at a healthy 14.4volts
    3. Checked grounding points, all good
    4. Checked relays for damage, all good no burnt contacts
    5. The alternator is charging, connectors all tight
    6. o2 sensors ???
    7. Just cleaned the throttle body
    8. Temp sensors ???
    9. Vacuum hose all tight and no pinhole leaks or cracks
    10. Will clean the IAC valve (its raining now)
    I'm thinking of spraying the connectors with electrical contact cleaner and look for flat or loose crimp connections.
    this is something i can do, is there any other area i am missing? Car doesnt show any error codes, so i'm guessing its some intermittent fault. if it was the fuel pump it would not have made that buzzing sound (its relatively new) and i had it checked for pressure delivery, all good. fuel filter not clogged, car running on Ron 98
    I hate to be driving and then the car will stall with no warning
    vts 1999 V6
    Oct 2011
    VT Series 1 V6
    Jan 2008
    Have you checked the fuel system for clogged filter, dodgy relay or fuel pump on the way out?
    Hangman's Avatar
    Hangman is online now Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Quote Originally Posted by Not_An_Abba_Fan View Post
    This.
    How exactly did you check the CAS?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Just because no error code does not mean its not faulty. Issues you mention i would replace it anyway and mentioned several times already.
    VX Executive
    Feb 2008
    Ok, maybe i wasnt too clear. the mechanic changed to a new CAS sensor and the car still stalled. finally changed the module under the 3 ignition coils and this seemed to solve the problem. For two days the car ran trouble free...
    Last night it stalled again. Earlier in the day i went through a checklist, waited for the rain to stop and then cleaned the throttle body, airtube, air filter, checked all the connections and cleaned out the IAC valve...
    I double checked the spark plug lead and then...when i was just LOOKING at the vacuum hose, the damn thing broke!
    There's a vacuum hose from the back of the supercharger to the front of the 'nose' part which connects to some kind of mechanism which looks like a control vacuum valve or something. The L-shaped rubber connector broke clean in half and when i blew through the tube, bits of rubber fell out.
    Can a broken vacuum valve stall an engine? I'm kinda peeved that if can contribute to the engine stalling, then this weak part is like the 'unguarded exhaust port on the Death Star'
    Since its a holiday here, i'll pop down to the shop for replacements and hope this little thing fixed will solve the problem!!
    VX Executive
    Feb 2008
    Car was behaving well in front of the mechanic(s). did a second fuel pressure test and came up with routine numbers. this got me totally stumped.
    VB SL/E
    Dec 2008
    [QUOTE=blacknight;2047078]
    Can a broken vacuum valve stall an engine? [quote]
    Yep.
    VX Executive
    Feb 2008
    Its just a plastic tube with two rubber L-shaped connectors on each end. I am an RC Racer, i have some silicone tubing which i can use to replace this p.o.s tube. Cross my fingers to see if this is the cure
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, that hose can cause it to stall.
  15. #15
    VX Executive
    Feb 2008
    now i'm wondering if this $3 tube was ll it took to get the car from stalling again...instead of spending $$$ on new coil packs, diagnostics and the ignition module!
  16. #16
    VT Series 1 V6
    Jan 2008
    mate, sometimes that's what it takes, particularly when your mechanic can't seem to fix the problem. I always start with the simplest cause, usually it's the right one. I hope it fixes your problem. Those other bits would eventually need replacing anyway, so look on it as preventative maintenance.
  17. #17
    VX Executive
    Feb 2008
    I'm brooding bcoz i have this thought at the back of my head that maybe the repairs could have cost less than $10, instead of all that checking and replacing parts. the car is still behaving very well, absolutely no problems but i am keeping an eye and both ears open for any symptoms if the stalling gremlin returns
  18. #18
    VX Executive
    Feb 2008
    This time it stalled again!!!
    In the middle of heavy traffic i had to get off the damn highway before i got myself rear ended. All the while i was losing power steering, no engine response , the brakes were fading. COMPLETE ENGINE SHUTDOWN!!
    I had changed the vacuum hose which i found to be cracked and the car was behaving well for two days. But after going home on the back of the tow truck, this car is beginning to piss me off.
    what havent i done to check and damn well replace EVERYTHING on the previous checklist???
  19. #19
    Hangman's Avatar
    Jan 2010
    The brakes were fading?
  20. #20
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by Hangman View Post
    Probably just meant no power braking. If you don't push the pedal harder the car ain't going to stop well.
    Ronald Reagan (1986)
  21. #21
    Hangman's Avatar
    Jan 2010
    My bad, I read it literally.
  22. #22
    VT Series 1 V6
    Jan 2008
    Sorry to harp on dude, but you haven't mentioned anything about your fuel system being checked. Pump, filter, relay all can cause stalling.
  23. #23
    vts 1999 V6
    Oct 2011
    HI
    i have a VT v6 1999 MAY auto with the same problems (when hot weather)
    tomorrow I'm going to replace the CAS sensor again!!!!!!!! and the CAM sensor.
  24. #24
    VX Executive
    Feb 2008
    The fuel pump is all good, checked the fuel rails (three times) and its registering a very healthy pressure under all RPMs. No stuttering, no lack of fuel pressure. this was tested at the agent. New filter is not clogged and the relay, if it was faulty, wouldnt fire up the pump. changed it with a new one and checked the terminals for corrosion. Changed the fuel line and absolutely no difference. Car still stalls....I'm now waiting in the customer's lounge in the holden shop wondering what other gremlins can still be there making my car to stall.
    Exhausted ALL avenues...
  25. #25
    VY S V6 Ute Series II 2004
    Nov 2009
    Check the wiring harness connection that joins onto the DFI module.
    Its common to get a loose connection there that will make the car stop intermittently. The connection's pins have all got to be spotlessly clean and a nice firm fit.
    Replaced my crank angle sensor a while ago with car having same problem you're having and it still played up. Dodgy connection was the problem all along.
  1. NO SPARK VN V8 and changed dizzy,plugs,leads,module and coil HELP!!!!
    By chooka82 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2010, 11:24 PM
  2. VE Stalls, Cruise Control De-activates, Engine Safety Module?
    By Holdfast in forum VE Holden Commodore (2006 - ?)
    Last Post: 11-09-2009, 03:04 PM
  3. soldering a power window module/circuit board
    By rogue_red in forum Electrical Wiring / Questions
    Last Post: 17-10-2007, 05:49 PM
