Results 1 to 7 of 7
Thread: vt s/c 6 rattle
    Vt seriesII XU6
    Apr 2009
    Default vt s/c 6 rattle
    Hey guys.
    driving home tonight started hearing a fairly noticeable rattle coming from the motor just as i pulled into home. cant work out where its coming from, sounds like the drivers side of the motor. Rattle seems to disappear when engine revs increase, but is really loud on idle. Weird thing is, on the same drive, i noticed some weird clunks and squeaks from my (brand new) diff when it changes into second. cant see how they could possibly be related and probably just due to the fact my car is cursed from ass to tip.
    Before i take it somewhere and get reamed (again) anyone have any suggestions abou what the hell could be going on and some quick diy diagnostic techniques to work out if theyre right?? would love to work this out tonight/tomorrow morn.
    cheers guys.
    pete.
    VY SII HBD Calais L67
    Dec 2006
    Whenever I look for the cause f n issue it usually relates or is a result of recently completed work on the car. If your diff has recently been done there is a chance the cat back exhaust was dropped to do the job even though it's unlikely. If the tail shaft was worked on the exhaust would have been dropped so there could be a cause for your noise stemming from an incorrectly located exhaust rubber mount/ hanger. If the trans has been worked on recently the starter motor heat shield may have been damaged and could be vibrating against the starter.
    I guess just have a look see in the engine bay and see if things move that shouldn't. With repetitive noises you ca usually find witness marks if somethings ben rubbing so that's another thing to suss out possibly
    VYII Calais L67
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    One of the idler pulleys could have sit themselves, that would cause a rattle.
    With the diff, I agree that the exhaust may be rattling somewhere.
    Visit my Facebook page
    VS GTS & VT XU6
    May 2011
    good chance the rattle in the engine bay is your coupler its a common problem with these listen to the frot of the charger does it sound like it could be from there ?
    does it sound a little like this ?
    Bad Blower Coupler - YouTube
    if so i got this kit well worth it and you have the bearings if you decide you want to replace them down the track
    Eaton M90 Supercharger Snout Rebuild Repair Bearing Kit | eBay
    Vt seriesII XU6
    Apr 2009
    Thanks for all it help guys. Yeah that video sounds pretty much identical just not as loud. It's definitely something pulley related. Doesn't seem to have effected performance too much I don't think. Found a mutual friend working at a local Holden dealer so dropped it off this morning and should have an answer soon. Let yas know what happens.
    Thanks again boys
    Pete.
    Vt seriesII XU6
    Apr 2009
    Turned out to be the harmonic balancer. They offered to source me a genuine Holden part for 950 incl labor!!! Bursons had one for $180. That plus 2 hour labor. Not too bad an outcome. Given that I droe about 20ks with it rattling to shit today, are there any other things I should be concerned about??
    *uwishn* is offline Holden special vehicles
    vl walkinshaw(replica) vt clubsport r8
    Jul 2010
    sydney
    Quote Originally Posted by vn50L View Post
    Hey guys.
    cheers guys.
    pete.
    good i'm not the only one who has a POS cursed vt haha
    My VL Walkinshaw replica project
  1. Vr rattle
    By Pickle' in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 08:45 PM
  2. l67 rattle
    By vs_statesman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2009, 11:06 PM
  3. Got a Rattle???
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 01:46 PM
  4. Door Rattle - Yes the Rattle that hunts Holdens
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2006, 09:01 PM
  5. vs rattle
    By crainy in forum Car Audio
    Last Post: 20-06-2005, 12:09 PM
