Results 1 to 12 of 12
Thread: is it time for a new battery?
    VX Berlina II
    Sep 2011
    Default is it time for a new battery?
    Hey, normally my car starts straight away but this morning when i went off to work it took about 10 seconds to start then about 2 hours later i had to move it to a different park and i couldnt get it to start for about 1 minute, there has been about 2 other times where it took maybe 3 seconds or so to start as well im not sure when the battery was last changed as i have only had the car for a bit over a month, but it does still have the acdelco one in there, i dont know if its the original and has lasted the 9 years (167000 k's) or not, also when buying a new battery would i be stupid going to holden to buy another acdelco battery or is any heavy duty battery exactly the same?
    cheers
    vx v6 comodore
    Jan 2011
    sunshine coast
    If your car turn's over then the battrey is ok, If it just makes like a clicking sound and doesent turn over then the battrey is bad.
    Or if the starter motor is turning over extreamly slow the batt is bad.
    If it wont hold a charge the batt is bad.
    Most battrey stores will test it for you for free.
    No point going to holden for a battrey, you will just get ripped off, I have a SSB manance free battrey atm and i find it great! $118rrp 600cca.
    Any decent battrey will do fine, just dont go for a chepie like supercheap sells, they only last a few month's.
    In my opinion i wouldent recommend century battreys, In my experiance and as far as i have seen they are crap.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I really doubt it is the original battery.
    Tell us more about what is happening because we can't tell from what you have written.
    Which of the symptoms that vx_commodore has described is it displaying.
    MY RIDE
    VX Berlina II
    Sep 2011
    Quote Originally Posted by vx_commodore View Post
    Yes it was still making the noise it normally makes when you start it and there was no clicking sound, so does this mean its not the battery, im not sure if the battery is bad or not but when i bought the car i did have to clean off a bit of corrosion, so could it be old?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I doesn't sound like the battery and the fact that there is corrosion (I assume you mean on the terminals) doesn't mean the battery is old. Pour some boiling water on the terminals and that will dissolve that build up.
    So you say it turns over like usual but won't start?
    MY RIDE
    VX Berlina II
    Sep 2011
    Quote Originally Posted by accentstencil View Post
    Yes the corrosion was on the terminals and i had already cleaned it off easily with a wire brush and boiling water, yes it was sounding the same as usual but was not starting, took about a minute to start but on the way back home it started straight away and i tried it just before again and it started straight away, so im not sure what caused it?
    VX Berlina II
    Sep 2011
    Went to battery world and got my battery tested, the guy said it had low cca or something and i should get a new one, from what he could see he thinks it was put in 2005, not sure if this was my problem or not but yeah
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    If it was put in in 2005 I would definitely get a new one. It is 6 years old and they only usually last about 5 years.
    MY RIDE
    executive vt 5.0lt
    Feb 2005
    west suburbs
    VY S V6 Ute Series II 2004
    Nov 2009
    cheers
    Sounds like your car's trying to tell you something...
    "Help... I need a.... service...
    Seriously though it would probably solve you problem if it hasn't been done for a while.
    VX Berlina II
    Sep 2011
    Yes i have only had the car for a bit over a month and am planning on changing over everything soon, as for the battery i ended up buying a Hi performance century battery, see how it goes
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I ended up getting a needing battery yesterday too, mine was only a bit over two years old and it wasn't cheap, $150. Luckily it had a 3 year warranty so the replacement cost nothing.
    MY RIDE
  1. hey guys 1st time poster long time reader
    By vpmanua in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2011, 09:43 AM
  2. Replies: 1
    Last Post: 29-09-2010, 06:51 PM
  3. I changed the regulator, now the battery light is on ALL the time?? Help Please
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2010, 11:13 AM
  4. Time to get get a new battery
    By speed_freak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2010, 10:22 AM
  5. engine light on and stall time to time asap help
    By kevinwilly123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2009, 09:32 AM
