Results 1 to 6 of 6
Thread: My headlights are on drugs.. help?
    VT Berlina S1
    Dec 2009
    Adelade SA
    Default My headlights are on drugs.. help?
    Angel Eye dramas
    https://www.facebook.com/photo.php?v=2029127226449
    Story goes.
    Driving to Melbourne from Adelaide, a small rubber object (soccer ball size) fell off the back of a passing truck and struck the drivers fron corner somewhere.
    Since then...
    1. parkers seemingly work fine initially
    2. turn headlights on, drivers side is dull and parkers brighten
    3. pull highbeam paddle, driver side doesnt work, parkers dull.
    4. flick highbeam paddle on, drivers side doesnt work, parkers reappear, headlights both go out.
    Is this a earth problem? fuze? pinched wires? do i need an auto electrician?
    Have tested problematic headlight glove against car and battery and the globe is fine. its something to do with the wiring.
    VT Berlina S1
    Dec 2009
    Adelade SA
    ..and its friday night :/ cant see anyone about it til monday.. not impressed.
    VY SS
    May 2011
    Auckland
    Everything except 2 suggests its a problem with the ground. As you draw more current they dim or go out.
    Do the angel eyes use the same plugs for the bulbs as the standard lights? If not can you try the standard lights?
    There are 3 or 4 fuses and relays that control your headlights. Maybe for sanity, fleece some of the other relays (check they're the same part number though) and try that. Also either replace the fuses or test the resistance with a multimeter, if they're partially blown you'll still get some voltage but it will drop off significantly as you draw more current (actually a bit like what's happening).
    Sorry this isnt very organized, kinda thinking of stuff as I write. Good luck
    FPV GT-P Boss 335 & 2000 VX Berlina 5.7lt (toy)
    Jul 2010
    Dalby
    or you could avoid driving of a night till you can get to see a auto sparky on monday......less hassles for you that way. He will probibly have it sorted in 10 minutes
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    What you could do, test out the plug that goes into the headlights and see if they are working fine.
    really looks like a earthing problem tbh
    I'm not sure if your lights has the same but my brothers altezza lights have a cable that you have to mount to the body, so if yours has that check that out? :S
    oh and, It's a commodore
    haha sorry. jokes
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VT Berlina S1
    Dec 2009
    Adelade SA
    Over it, lights have been replaced.. all down to the 6 pin plugs.. no messy wiring behind stock lights..
    high beams still draw power from passenger low beam when off, only drivers highbeam works when on and passenger low beam dulls. Am pulling my hair out with this, relays work fine, fuses work fine, new globes in replacement lights...
    Out of ideas.
  1. why do drugs 4
    By vn chicky in forum Jokes/Humour
    Last Post: 24-04-2007, 01:03 AM
  2. why drugs are bad
    By Troy711 in forum The Pub
    Last Post: 14-05-2006, 03:55 PM
  3. What drugs do
    By The1985divo in forum Jokes/Humour
    Last Post: 20-10-2004, 08:01 PM
Tags for this Thread
