Results 1 to 2 of 2
Thread: Shudder turning left
    VX
    Dec 2011
    Currimundi
    Default Shudder turning left
    Hi I have a VX and when you turn left a bit and brake there is a shudder but if you apply a bit harder or turn left slightly more it fades out, does not do it in a straight line or if you turn right would this be a tie rod or rack end I have replaced the rotors not that long ago?
    PSI2FLY is offline Default
    97 VT SS 5.0 Man
    Jun 2009
    Mascot
    Could be tie rod end. Next time ur at ur car make sure the wheel is straight and grab it with both hands and try to turn it left and right. If its tie rod end you'll hear it clunk on each push and pull, also look at the bushes.
    Another key factor is the disc could be warped and also running bare on brake pads.
  1. Replies: 15
    Last Post: 27-11-2011, 10:16 PM
  2. Rear Shudder turning corners VYII Clubsport
    By fiBer in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-03-2011, 12:15 PM
  3. noise from front left tire when turning left. help plz
    By 17UCK! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-02-2011, 09:20 PM
  4. VP rear/left wheel shudder upon hard acceleration turing left.
    By sirsmokeallot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2010, 02:51 PM
  5. shudder from left rear wheel
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2007, 07:24 PM
