Results 1 to 7 of 7
Thread: Motor Swap VT LS1, Need help
    VT SS 5.7L
    Oct 2011
    Gawler
    Unhappy Motor Swap VT LS1, Need help
    hey there
    i have recently swapped over my ls1 as it developed a knock, and now it wont start, not even try kicking over =*[
    i labelled everything, undid electrical connectors, pulled out the trans with the motor.
    *note, the 2 plugs going into the trans gear selector were put in dodgily, held in by silicon therefore hard to get out
    Put the trans on the new motor, 6 hours later motor was all back in, all the plugs that we know of are done up, those two plugs going into the trans gear selector are plugged in but not sure if in properly, all looks good.
    I think that if its those two plugs that its not recognising its in park and not starting, but dont know for sure.
    if anyone has a one of these selector attachments that bolt onto the trans laying about, will pay for it + postage
    please help, any ideas or suggestions would be good, thankyou
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    The only thing I can think of is that skinny wire that goes to the starter motor, I forgot to plug that in on mine once and the ignition lights came on but it wouldn't turn over.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VT SS 5.7L
    Oct 2011
    Gawler
    Quote Originally Posted by superchargedvs6 View Post
    cheers for the reply, nah thats all hooked up.
    also, one of my mates got a bit of wire and went straight from the battery to that skinny wire and it cranked over so i think that means it has to be something inbetween when you turn the key to the 12v or so going to the starter
    VT feature car, WRX STI WAGON
    Aug 2006
    just so you are aware, those plugs are glued in from factory.
    i do have a couple of those selector attachments though.
    VT SS 5.7L
    Oct 2011
    Gawler
    Quote Originally Posted by CHEETR View Post
    Cheers, didnt know that, how are you suppose to get them out without stuffing it if its siliconed?
    also how much would you want for one? post to Adelaide? =]
    Aug 2006
    just takes a bit of patience.. i usually heat gun them to remove and use a small flat head
    $80 +$10 postage
    VT SS 5.7L
    Oct 2011
    Gawler
    alright will give that a go, how do you usually go about buying stuff on here? msg me on 0466565917
  1. motor swap
    By ecpt01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-07-2011, 11:54 AM
  2. vr motor swap to a vt
    By murpha1818 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-09-2010, 08:59 PM
  3. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  4. vr motor swap
    By blake0182 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2008, 09:00 PM
  5. vr to vs motor swap
    By redvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2007, 09:51 PM
Tags for this Thread
