Results 1 to 15 of 15
Thread: automatic transmission cant make up its mind shifting
    Holden vt calais 5 litre
    Nov 2007
    Default automatic transmission cant make up its mind shifting
    automatic transmission cant make up its mind shifting it keeps upshifting the downshifting while cruising its especially worse going uphill im getting abs error code's 21 and 23 (rhf speed sensor) i dont know if they are related
    vx v6 comodore
    Jan 2011
    sunshine coast
    Id say...not 100% sure but yeh id say it would be related...No harm in changing the speed sensor though!
    Also check your fluid, That will make the gearbox do strange things...
    Vt Vx use electronic kick down, Not like the old style kick down cables!, So it may use the speed sensor to figure out what to do...
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    is it with any gears? or just between 3rd and 4th?
    Going where no late model stato/caprice has gone before.... GAME ON!!
    Nov 2007
    Quote Originally Posted by walesy View Post
    yeah just 3rd and 4th
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Is this at about 70-85kph, at gentle inclines? And has zero idea about what gear it wants?
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    Nov 2007
    Quote Originally Posted by MikeCuzzy View Post
    yep I was doing 70kph it sounds like I'm not the only one with this problem
    VT 3.8 L67 in progress of turbo
    Dec 2011
    Canberra A.C.T
    I had the same problem do a trans service kit and fresh oil It will be alot happier
    Nov 2007
    Nov 2007
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Quote Originally Posted by CIRCLEWORK View Post
    +1 on this. Service the gearboxbox mate. Memcal wont fix the problem if the fluid has turned to muck.
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    '98 VT commodre
    Jun 2009
    melbourne, VIC
    I have the same issue in my VX wagon. it " flares" around 60km and also sometimes sitting at red lights it goes a wee bit silly aswell. ALso noticed that afew times driving home from eildon yesterday i would accelrate slightly and it seemed to drop down 2 gears and nearly redline ?????
    I thought it might be a shift solenoid or something as i did a trans service kit about a month ago ? ......
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    Sometimes my auto takes off in 2nd gear & not in 1st. It doesn't matter if i select it to 1 manually or if it's in D.
    then if i gun it hard it may or may not drop back into 1st
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    You can try a service, but in reality, this is a common fault with the gearbox. You'll find some people mention it alot, others don't have the problem. Go figure.
    Pay attention to how much accelerator you use and where it shifts, you can sort of make it do what you want after a while.
  15. #15
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    It's just been put back on after it got a stage II shift kit installed & some extra bands as well as HD bands too.
  1. Help Me Make Up My Mind!
    By RazzaCaine in forum General
    Last Post: 11-02-2011, 08:11 PM
  2. Cant make up my mind.
    By k3v0 in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-09-2010, 04:36 PM
  3. harsh automatic shifting if lever in 3 not in D
    By jeepster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2010, 04:45 PM
  4. Can't make up my mind
    By josh7243 in forum General
    Last Post: 25-05-2010, 05:26 PM
  5. Automatic Transmission Problem (Stick Shifting)!
    By JuStDaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2009, 07:56 PM
