So I've had a leak coming from my power steering reservoir for sometime now and it got really bad, started to leak down the hose onto the pump and eventually started to drip on my drive way. I cleaned up and changed the reservoir plus the hose connecting to the pump just to notice that it was neither of them leaking. When i took the old reservoir off i had it sitting on its side with a little bit of fluid still in there. I realsed that the cap was leaking yet I've already changed about two caps on the newly replaced reservoir. So after all it's the cap that has been leaking whilst driving.
Has anyone had the same problem with this dodgy cap leaking? It must be a manfuacturing fault because it's definitely not the reservoir or the hoses... Now im in search of an alternate way to keep this damn fluid in and not make a mess. Any solutions?
I haven't had the cap leak, but I have had to replace two PS reservoirs over the years as they start to leak around the join in the middle.
