Results 1 to 15 of 15
Thread: audio
    vt ss
    Dec 2011
    perth
    Default audio
    just driving down the road and my speakers stoped working...they are wired to a amp..checked the fuse on the amp and that is ok...checked the fuse on the red power cable and also looks ok...the light on the amp isnt on either...help
    VT SS 5.7 s2
    Oct 2011
    melbourne, western suburbs
    Jan 2008
    NSW
    Were you cranking the shit outta it? Its possible the amp overheated and went into protection.
    vt ss
    Dec 2011
    perth
    vx v6 comodore
    Jan 2011
    sunshine coast
    Multimeter will tell you what the problem is, Its either the main 12V from batt, Remote wire or Ground.
    something may be loose somehwere, Battrey conection or Earth maby.
    vt ss
    Dec 2011
    perth
    yea guna have to get my mate to put the multi meter on it.. i cant even find where its earthed to lol its too dark and i olny just bought the car thanks annnyway guys
    The_Doctor is offline Banned
    VE SSV Series 2 Redline
    Sep 2011
    Don't need a multi meter, just get a circuit tester, basically it's a bit of wire with a light globe in it, attach to earth and touch live and it lights up, handy as shit I use mine all the time and costs $6
    VS GTS & VT XU6
    May 2011
    if you just bought it there is no way of telling the state of the wiring job ive bought a few cars and who ever did the wiring should be shot or have there hands removed its suprising the cars hadnt burnt to the ground in this case id say remote wire is a good chance but id get it looked at by someone in the know to make sure everything else is sweet
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Also check the remote wire to the amp. I had 2 problems straight after I had my stereo system installed, 1 was the remote wire had a break it the wire, 2 was the earth was left loose.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    vt ss
    Dec 2011
    perth
    Quote Originally Posted by The_Doctor View Post
    where did u get it from??
    vt ss
    Dec 2011
    perth
    i dont know its weird ive checked all the wiring seems ok...in saying that there is alot ov joins like 2-3 joins.....it (the amp) flicks on and off like going ova a bump or shuting the door....turn the car on and off and still doesnt work until i hit a bump or decides it wants to work..ive had the car for 8 days now and its bin fine up until now....checked where the earth was ground to and its earthed pretty well....so got me stuffed might try the circuit tester
    vn s commodore
    Aug 2011
    carrum downs
    It sounds like there is a loose wire if its turning off and on when you go over bumps something is loose. Might be the wire with all the joins in it replace that wire and see if that fixes it.
    vt ss
    Dec 2011
    perth
    VT_sleeper's Avatar
    VT_sleeper is offline Don't G-Tech in reverse
    Black VX S II - Supercharged
    Jun 2008
    SE Suburbs of Melbourne
    Is it possible where you have run the remote wire which i assume is under the side trims that it has been pinch as you've gone over a large bump? I'd also wonder if the fuses have prehaps become a little lose.. Sounds like a connectivity issue thats for sure..
  15. #15
    vt ss
    Dec 2011
    perth
    Quote Originally Posted by VT_sleeper View Post
    i dont know but if it had pinched itself then y would it keep working some times?....checked all the amp fuse and thats fine and pushed it all the way...and checked the power fuse and its still in one pice
  1. [VIC] WTS: Option Audio Pro Series 12" 800w RMS Sub and Option Audio 800w RMS Monoblock
    By WHYtheFACE in forum Parts And Other Items For Sale
    Last Post: 22-11-2011, 09:02 PM
  2. New ASR-Audio Website now online! www.asr-audio.com.au
    By rch-13z in forum ASR Audio & Electronics
    Last Post: 02-08-2011, 09:49 PM
  3. Audio - AUX IN audio hiss/buzzing noise issues ? VE 2007
    By goldvn05 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-05-2011, 01:19 AM
  4. Help with VY audio
    By CoalM!NER in forum Car Audio
    Last Post: 20-03-2007, 09:56 PM
  5. not quite audio but is used for audio purposes...
    By Tasmaniak in forum Car Audio
    Last Post: 11-08-2005, 02:50 PM
