Results 1 to 16 of 16
Thread: Warning lights on and loses power
    98 VT HBD
    Aug 2009
    Default Warning lights on and loses power
    Hi guys
    Just driving down the road this morning, all the warning lights come on and then loses all power. I let it rest for a few minutes and try to restart. It restarts, but the oil, battery and I think it was transmission light (the one directly below the C on the temp guage) came on, started to shake / vibrate and dies as soon as I try to move it off the road. The car was running fine until this happened.
    Any ideas?
    VN SS
    Aug 2011
    Overland Corner
    98 VT HBD
    Aug 2009
    Not at all!
    My hubby seems to think it's the fuel filter, but how would that make the warning lights come on??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Melissa View Post
    Not at all!
    That wouldn't make the warning lights come on. I suspect that the oil and battery lights came on because it was shaking due it almost conking out and it wasn't revving high enough to build up oil pressure and also it wasn't turning the alternator fast enough. This is just a guess on my part. The other light you mentioned sounds like the engine warning light and therefore it should have logged a fault (error) code.
    Checking error codes VT/VX
    MY RIDE
    98 VT HBD
    Aug 2009
    We're having the car towed home later, so I'll check the codes then. Thanks!
    I just went back to the car to see if it would start. It wouldn't. Just sounded like it was out of petrol (it's not).
    Fingers crossed it's a cheap fix!
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Quote Originally Posted by accentstencil View Post
    +1 to this. Check the error codes first and report back.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Some times the distance to empty reading can play up and be right out. I've run out of fuel a few times with over 140km to go on the meter. It seems to have sorted itself out now.
    MY RIDE
    98 VT HBD
    Aug 2009
    I don't really take much notice of the distance to empty thing. I put fuel in yesterday, there are no leaks and had only driven a few k's, so I know there's enough in it to keep it going for now.
    I went back to the car before and the bloody thing started! I didn't even do anything to it. Strange. I'm happy she's back home.
    Both the kids are home from school now, so I'll check the error codes tomorrow.
    vt ss
    Dec 2011
    perth
    same thing happend to my old ute it turned out to be a sensor can rember the name tho
    vt ss
    Dec 2011
    perth
    Quote Originally Posted by dazzler View Post
    cant*
    remember sorry
    V6 - VX Series II Berlina (2002)
    Nov 2008
    Brisbane QLD
    VX Executive S2
    May 2006
    Frankston South Vic
    vx ss ls1
    Dec 2009
    Does the car start fine still? If not its most likely your main fuse blowing which iscaused by the starter mogor shorting out.Just have a look to see if any sparks are flying around when you touch the wire coming out of the starter. Or it could be the bracket of the starter. Which was my case last week.
    98 VT HBD
    Aug 2009
    Thanks guys. I haven't had a problem with it since! I still don't know what caused it to do that, but it seems to have sorted itself out.
    I tried to do that error code thing too but nothing happened. Not sure if I put the wire in far enough?
  15. #15
    VT 3.8 L67 in progress of turbo
    Dec 2011
    Canberra A.C.T
    abs module can do that or car has gone into limp mode
    CIRCLE WORK 97 VT COMMODORE 3.8L WORKED
  16. #16
    vs ss ute 5ltr
    Jan 2010
    sunnycoast
    my vs 5ltr did that a few days ago, it ended up being the coil, she would want to kick over but not start. in your case it could be coil or crank angle sensor, good luck.
  1. Replies: 61
    Last Post: 01-10-2011, 10:10 PM
  2. my mUms 94 Vr is stalling or maybe loses power briefly..
    By Badboy40qld in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2011, 09:19 AM
  3. Vt loses power uphil. HELP
    By Finnrizell in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-01-2011, 08:56 PM
  4. Car randomly drops/loses power/stalls?
    By MkyHnly in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2010, 12:19 AM
  5. VS - Ticking sound, oil light, loses power while turning
    By jobler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2009, 04:38 PM
