Results 1 to 2 of 2
Thread: Dismantle front console
    2001 VX ACCLAIM
    Dec 2011
    Paddington
    Default Dismantle front console
    The accessory 12v socket in front of auto gearshift is not powered up ,the only fuse that appears to relate is the cigarette 15 amp which is ok ,a cig. Lighter is not installed. I need to access the back of the accessory socket to check connection to the fuse board under steering wheel.
    How to dismantle the console is my question
    vx v6 comodore
    Jan 2011
    sunshine coast
    To get the trim off from around the gear stick, there is 2 screw's, 1 either side of the cig lighter.
    Undo them, then it will just lift out,(toward the back of the car) If you have power window's you have to lift the trim up enough to unclip the power window swich.
    Also, 2 more screws holding in the pocket unde the stereo, undo them and pull the pocket out.
    Thats all you have to take off to access the 12V socket.
    I suk at explaining things! But yeh just undo them 2 screw's, folowed by lift up trim and unclip power window swich, Then unplug the loom off the swich.
  1. removing ve omega roof console - front one
    By motive in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-10-2010, 11:55 AM
  2. How To Dismantle a 3.8L Engine
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2008, 09:20 AM
  3. Dismantle or resurrect
    By vlrad in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-08-2005, 09:48 PM
  4. VK dash dismantle
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-06-2005, 12:08 AM
  5. How to Dismantle
    By motors405 in forum Car Audio
    Last Post: 31-03-2005, 10:44 PM
