Results 1 to 12 of 12
Thread: Purge valve question.
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Default Purge valve question.
    Hi peeps
    My question is, the purge valve on the driver side on the back of the head (s1 ecotec) one outlet goes under the plenum to the inlet manifold. What about the other one?
    Thanks in advance!
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Thats the canister purge solenoid. The other hose will go to the charcoal canister which on your vt will be under the two fuel line connections on the firewall.
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Quote Originally Posted by CUR53VT View Post
    Hi peeps
    Thanks in advance!
    I tought i answered this last night,obviously you didnt understand.Hmmmmmmmmm,lets try this,,,,
    Attached Images Attached Images
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Nah just me Bering a fool. On the purge valve, which outlet goes to which (throttle, canister)
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    Middle one to canister,the one close to the plenium to throttle body.
    Attached Thumbnails Attached Thumbnails Purge valve question.-screenhunter_02-dec.-10-00.45.jpg   Purge valve question.-screenhunter_03-dec.-10-00.46.jpg
    S1 VT Wagon
    Apr 2005
    Gold Coast
    mate, thank you so much. seems i had the hoses the wrong way around. could this affect how the car runs? also, where did u get those diagrams from, they're excellent
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    S1 VT Wagon
    Apr 2005
    Gold Coast
    will swap them around first thing in the morning and see how it goes. such a pain in the arse to get to though. and that stupid one that goes to the throttle body, nightmare. if only holden had made them an inch longer.
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    S1 VT Wagon
    Apr 2005
    Gold Coast
    hahaha the cash flow to get someone else to make this their headache?
    2 quick little things. the earth point on the back of the passenger side head. the heads were painted when i got them back. should i sand it back to metal for the earth, or shouldnt it matter? and the intake manifold seals, the ones to the block. which way do they go on? i assume they go on like an upside down "U", with the cut out over the edges of the block, and the ribbed side to the inlet base. problem is, the seals were kind of skinny, and when put over the block, they stretched out, and didnt have a flush fit. is that normal? there are a few other questions posed in another thread about plug lead/coil pack order just for process of elimination, and a plug wet with unburnt fuel. so all in all, the list of known problems or queries is getting smaller, so it has to be one of those.
    VTS5's Avatar
    Jul 2005
    Sth.East\Melb
    vy fagon, ve ssv, vr BT1
    Dec 2011
    hood
    Quote Originally Posted by VTS5 View Post
    Would this be the same on a Vy?? Having trouble finding the purge hose
    Not the throttle body end
  1. M90 supercharger bypass valve question
    By frdhtr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2010, 03:32 PM
  2. VZ S Ute valve timing and exhaust question
    By johnn in forum V6 Development And Modification
    Last Post: 28-04-2010, 06:33 PM
  3. question about an iac by-pass valve
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2006, 10:05 PM
  4. Quick Question re: Valve Stem Seals
    By fitzy2005 in forum General
    Last Post: 06-05-2006, 03:35 PM
