Results 1 to 13 of 13
Thread: Various cluster lights not working
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Default Various cluster lights not working
    Hey guys,
    My car is a VTII Calais International - Super 6, 90,000KM's - Level 3 Dash
    I purchased the car in May with this problem (that I didnt notice at the time).
    Various cluster lights dont work (or work properly):
    Seatbelt light - Will come on when car is started but will go out within 3 seconds regardless of whether your seatbelt it fastened or not.
    Parker light (cluster) - Wont turn on.. ever. The actual parker lights work fine.
    Dash buzzer/dinger/overspeed alarm/whatever you wanna call it - Doesnt work.
    What lights I know works fine:
    Abs, track off, low track, CEL, indicators, low fuel, temp warning, overspeed,
    A few months before I bought the car it did have the ABS module replaced.. if that's of any relevance.
    No error codes, or dash error codes.
    Please no talk of "Cop mode" . This car was previously owned by an old man with white hair coming out his ears.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The seat belt light does only come on for a few seconds when you start the car, it is just a reminder and doesn't light up if your seatbelt is not on. In other words, it's normal.
    MY RIDE
    vx v6 comodore
    Jan 2011
    sunshine coast
    There is not a light for parker's. Or do u mean when you turn parker's on the dash doesent light up?
    The overspeed charm is inside the cluster, so if it is not working, Just open the cluster and see whats going on. wont be a big problem.
    No need for talk of cop mode.
    VX Commodore Executive
    Jun 2011
    Central Coast
    If you press ther Mode button while turning on the ignition, the cluster will go into set-up mode (or some such). Then press the mode button several times and one of the settings will show ALL the warning lights, dash messages and activate all the guages. So you can see what is working and what is not.
    If all the warning lights are working, then the problem is in the device sending the warning, not the cluster.
    (Another setting of the mode button does go into Police mode, but it reverts to normal mode when the ignition is turned off).
    Cheers,
    JG
    Jul 2011
    Yes I know about the mode+up trip computer tricks and the 'christmas tree' mode. Everything works except the dash buzzer in christmas tree mode.
    @vx_commodore: See picture.. although now that I see it illuminated I see its red and has an exclamation point in it.. so then its not for parkers...
    It now looks like it's just the dash buzzer that's gone.
    I'm amazed that a car made in 2000 with driver AND passenger air bags doesn't remind you to put on your seatbelt.
    Even my mums old Daewoo bongs at you to put on your seatbelt.
    Attached Thumbnails Attached Thumbnails Various cluster lights not working-img_20111208_150615_1.jpg
    GIMPY1's Avatar
    GIMPY1 is offline Bass Slappin Mag Designer
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    ummm from memroy, (and feel free to correct me) that light your after is a warning that there is a dud globe somewhere, weather it be a blinker, taillight etc!
    And once again, please correct me if im wrong!
    Quote Originally Posted by elmaso View Post
    maybe the guys really wasted, like 24/7, you know how booze can some times lead to hookin in with some fugly chick, well thats probably what happened with him and the car.
    GIMP Mobile V2.0 - In Progress
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by GIMPY1 View Post
    Partly correct. If it comes on when the lights a switched on it means there is blown tailight globe or numberplate globe, if it comes on when you brake, it means a brake light globe has blown.
    MY RIDE
    Jul 2011
    Thanks for all the info guys.
    Before I get slapped with the "use the search engine" stick, I have looked and googled and found nothing about the dash buzzer.
    If its stuffed, does it mean the cluster has to be replaced?
    How does it get replaced?
    GIMPY1's Avatar
    VT Aclaim Wagon
    Dec 2007
    Ballarat
    Darn! pretty close!
    Wreckers should have them and they are quite simple to install as well! im sure ive seen a few threads with a bit of a how too!
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    does ur cluster have the digital speedo come on the LCD screen and stay on with out using ur trip buttons? if so some1 may have had the digital speedo put on and that does disable ur speed alert/buzzer.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Jul 2011
    Quote Originally Posted by wrx884 View Post
    Nope. As I said. Its untouched by the original owner.
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    if OK to slightly hijack...
    My middle green bulb does not work on the dash cluster (the one that shows total KM's etc on the car)...
    I have a WH Caprice with what i would imagine is the full range cluster installed.
    Any suggestions on how to remove/change that darn globe?
    MR_VX's Avatar
    MR_VX is online now Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    sounds like a blown bulb lad, The cluster has to be removed and swap the bulb over. not a hard/big job. there is a few threads on how to remove
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  1. VX calais triple window cluster, trip computer not working/window lights
    By CHEETR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2011, 06:48 AM
  2. VR Cluster Lights Not Working
    By themann in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2008, 05:15 AM
  3. level 3 cluster - some lights not working
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2007, 12:02 AM
  4. Lights in cluster are'nt working HELP!!!!!!
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2006, 09:13 PM
  5. cluster lights and speed alert not working
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:47 PM
