Results 1 to 8 of 8
Thread: Radiator Fluid Spewing Out
    VT
    Dec 2011
    melbourne burwood
    Default Radiator Fluid Spewing Out
    Hi guys,
    I am new to forum and have quick question if anyone would be nice enough to answer for me.
    I have just picked my VT 2000 commodore up from holden because car was showing error message,they said needed new BCM.Ok paid the $900
    Left holden drove for 15 mins,came out of supermarket and green radiator fluid all over carpark spot.Leaving car park bloke pulls me up to say leaking from front end.Car not showing overheating,showing half way.Got home after 5 mins no more fluid leaking.When i put car into holden was not spewing radiater fluid so wondering if this could be overflow,seemed like hell of alot of green fluid coming out.
    I am female and no nothing about cars so please excuse if there is an easy answer. -_-
    Thanks
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Did they (Holden) do a service as well?
    Might have been overfilled but from the amount your describing you may want to wait until the engine is no longer hot and take off the radiator cap to check there is still some coolant. Wait until the car has cooled off a bit and then put a rag on over the cap as you turn it as it will probably still have some pressure under it and may be hot.
    Look at all the pipes coming from the radiator for signs of leaks.
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    hmm sounds like overflow, because there were no signs of over heating. your best bet would be to go to your local mechanic and just ask them to do a pressure test on your system and that will tell you if you have leaks anywhere. ie: a split radiator.
    but check your coolant levels and if they are full and fine it might just be overflow, but if your loosing coolant then you have a leak.
    hope this can help.
    Dan.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VT
    Dec 2011
    melbourne burwood
    thanx heaps guys,i have taken cap off and needed coolant but after like a minute it all started bubbling back out,so i think i'll have to find a decent/honest mechanic to do a test.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check the coolant level in the reserve tank (to the right of the radiator with a yellow cap) if that has been over-filled it will leak coolant when hot. Also try a new radiator cap.
    MY RIDE
    Jul 2011
    Quote Originally Posted by Cashman_309 View Post
    If they did there is always the chance they just over filled it.
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    15 year old apprentices often have no idea what they are doing.
    Jul 2011
    I have a mate who works at a dealer / service centre. He has told me some shocking stories of the things they mess up.
  1. Overheated VT - Pink fluid in radiator
    By just_vt_problems in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2010, 08:37 PM
  2. Trans fluid leak - radiator
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-10-2009, 07:26 AM
  3. How do I change the radiator fluid [VR]
    By CrimsonThunder in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2009, 08:36 PM
  4. Changing Radiator fluid/Clean - Help
    By brayden_87 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2008, 03:00 PM
  5. changing radiator fluid
    By maccona35 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-06-2006, 05:04 AM
