Results 1 to 3 of 3
Thread: changing vt z bar bushes ?
    vn commodore
    Jan 2011
    brisbane
    Default changing vt z bar bushes ?
    hey guys i recently went for a wheel aligment only to find out my z bar bushes are flogged out. i got qouted $550 to do them and upper and lower control arm bushes and a wheel aligment. how much effort is involved to do it at home? is it worth paying for the labour ?
    cheers
    VX Calais LS1, VS Calais L36
    Mar 2010
    Upper and lower control arm bushes? There's no upper control arm...
    There is, however a strut top bush. Perhaps that is what was meant.
    There's three bushes, inner and outer control arm and front radius rod. Probably $200 in bushes.
    Getting the old control arm bushes out can be a pain (assuming they are factory) because they are contained in a pressed in steel sleeve. If you use two piece bushes they are easy to get in. Front radius rod bush is also easy.
    Strut top bushes are $100pr from Holden. Once the strut is out that's just a nut to undo on the shock, but you'll probably need a spring compressor.
    vxcustom's Avatar
    vxcustom is offline VXXX
    vx v6 executive
    Feb 2009
    Cranbourne, Victoria
    To do the z bar bushes is very very easy I did mine in about hour and half from start to finish and that included replacing the z bars themselves with hd nolathene z bars, nolathene z bar bushes (with adjustable caster). The hardest part was getting the bushes out of the control arm however I found that by using a very small drill bit and a hand drill i was able to drill through the rubber without touching the metal. After putting in about 5 or six holes (all the way through) I used a socket and a gentle adjuster (hammer for those that don't understand) and just knocked 'em out.
    Made a difference to the handling as i added half a degree of extra caster into the front.
  1. help with changing sway bar link and bushes on vy commodore
    By jewie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-08-2011, 11:32 PM
  2. changing link pin bushes!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-07-2009, 11:06 PM
  3. Changing the Bushes
    By werlegiggy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2008, 07:24 PM
  4. Caster bar bushes and rear cross member bushes
    By Galixia in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2008, 08:32 PM
  5. Z bar bushes or Radius Rod bushes?
    By Shounak in forum General
    Last Post: 12-04-2006, 05:29 PM
