Results 1 to 5 of 5
Thread: starting problems
    vs exec series 1 and vt series 2 acclaim
    Jan 2006
    Default starting problems
    Hi all got a wee bit of a problem starting my vt sometimes usually if it sits for 20 or more minutes it starts begrudgingly if it cranks like a flat battery but i've tried different batteries i tried replacing the brushes in my alternator seems to be the same sort of getting a bit frustrated if i only drive a short distance it starts ok and if i stop to say get fuel then try to start it straight away cranks slow like flat battery then nothing does anyone have any suggestions
    thanx
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Could be worn out starter motor.
    MY RIDE
    vn s commodore
    Aug 2011
    carrum downs
    S1 VT Wagon
    Apr 2005
    Gold Coast
    x3 starter motor. i had the same problem, just dont leave it as long as i did, ended up melting the terminals, mechanic needed to grind bolts of.... not good.
    Jan 2006
    cheers thanks guys will hop into it asap
  1. VG ute starting problems
    By Brad-19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2011, 07:58 PM
  2. VZ SS random problems starting and also lock problems.
    By alista in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-12-2010, 11:23 PM
  3. starting problems
    By hydratrac in forum Electrical Wiring / Questions
    Last Post: 17-07-2009, 12:03 AM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. Starting problems
    By noodle2100 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2006, 09:20 PM
