Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By VYMAD
Thread: Transmission Pan Gasket
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Default Transmission Pan Gasket
    The transmission pan gasket is leaking on my VX , I gave it a service a couple of months ago and the gasket seemed a fraction small and now it is leaking . I tightend the bolts and made it worse . Just wondering if you should soak the gasket in trans fluid before fitting or just use gasket sealant.
    Thanks in advance, Dave .
    VYMAD's Avatar
    VYMAD is online now SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I have always fitted them dry, no sealant and torqued to 11NM.
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Is it a cork or rubber gasket?
    I hear the cork gaskets are rubbish.
    Do not overtighten the bolts, you'll just break something.
    Always use genuine parts when it comes to transmission servicing.
    VT S2 Calais 5.7 A4
    Aug 2005
    And there are two types(sizes?) of gaskets as I know now from personal experience
    VX 'S' S1
    Apr 2005
    South East,Victoria
    Ok Jobs done . The old one was rubber which fell apart when i took the pan off , I replaced it with a cork one . Alls good ( so far )
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I've only ever used cork gskets, torqued to 11NM. They are fine.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I only ever use cork as well. The reason you don't over tighten the bolts is because it squishes the gasket out and causes leaks, not because it will break anything.
    Visit my Facebook page
    Jul 2011
    Eeep. Looks like I had it the other way round. Although, I've never had problems with genuine rubber gaskets
  1. Head gasket or inlet manifold gasket? HELP!
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2011, 03:54 PM
  2. head gasket or intake manifold gasket? how to tell? bit of assistance
    By Go_Slow in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2011, 04:26 PM
  3. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  4. Flange Gasket and Exhaust Manifold Gasket
    By mrvdv85 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-09-2009, 06:46 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
