Results 1 to 11 of 11
Thread: MAF Sensor cleaning
    VX Berlina II
    Sep 2011
    Default MAF Sensor cleaning
    Hey, have replaced my air filter today so tomorrow i want to clean the MAF going to go out and buy some crc maf cleaner, anyway do i just unscrew/unbolt it and give it a good spray all over and inside of it then let it sit to dry for a while? also i have read there is a part on it you shouldnt touch or you will need a new one what part do i not touch? does this just mean i dont touch it with my hands and not spray it at all either? also i read you give your intake air temperature sensor a squirt while your there too thats just the wires sticking into the rear of the air box yeah?
    cheers
    vr wagon
    Aug 2010
    vic
    Un plug your negative battery terminal. Unplug your maf. Undo the 2 clamps holding it to your intake (with the airbox lid undone is easiest) take msg out gently. the sensor is located on the inside of it. With crc Mac cleaner, spray generously around the inside. If yours has the honeycomb spray from throttle body side first as there will be bugs and grime stuck to the honeycomb and don't want it on the sensor. Then spray all connections on it. the plug you take off in first step I usually unplug that too and give all connections a good spray. And with air filter out spray air temp sensor. Leave maf sensor in a dry well ventilated area and leave dry. Shake cleaner out of plug connections. and leave dry. good idea to do your throttle body too while you have the intake apart and clean your iac as this gets a fair bit of carbon build up.
    VX Berlina II
    Sep 2011
    Quote Originally Posted by CHA53R View Post
    alright thanks for that, the throttle body is the part on the other end of the air box hose thing on the side of engine yeah? not sure what the IAC is though
    VX Berlina II
    Sep 2011
    Quote Originally Posted by daNc View Post
    Ok cleaned maf sensor, IAT and connections. Throttle body had lots of black stuff, squirted quite a bit of cleaner on it didnt worry about the IAC valve because im not sure where it is. Also when taking off the engine cover there is quite a bit of dirt and dust on it, not sure of the best way to remove it all?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Degreaser and a hose should clean it up a bit
    VX Berlina II
    Sep 2011
    didnt actually remove the t/b so theres probably still a bit of stuff left in the rear of it but im sure it is alot better than it was
    VYMAD's Avatar
    VYMAD is online now SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Good idea to read the How-To on throttle body and inlet manifold cleaning. May as well go the whole hog, there will be a lot of crap in inlet m'fold.
    vr wagon
    Aug 2010
    vic
    On the throttle body there are 2 sensors. Left side is the TPS the other is IAC. Undo the iac with battery unplugged clean it up side down and check there is movement back and forth in it. Shake the cleaner out and allow to dry.The valve will have carbon build up and sometimes become sticky and won't move. Giving rough idsle and poor fuel economy. Like the maf it controls your fuel to air mixture and worth doing. Clean your throttle body and intake and your away
    VX Berlina II
    Sep 2011
    hey there was nothing connected to the right side of it, are you talking about the one right above the throttle body?
    vr wagon
    Aug 2010
    vic
    vr wagon
    Aug 2010
    vic
    And if your taking your throttle body off don't forget to plug anything back in lol. there is your 2 sensors and 2 hoses, one in the left side and one in the back. check your gasket is in good order too.
  1. Cleaning your MAF Sensor
    By jesse'sVT5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2010, 08:49 PM
  2. Cleaning Around O2 Sensor
    By joe seinfeld in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2010, 01:09 PM
  3. cleaning MAF sensor
    By jas98 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2009, 11:01 PM
  4. cleaning oxygen sensor vs v6 ?
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2007, 01:53 PM
  5. Cleaning MAF sensor
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 03:54 PM
