Results 1 to 3 of 3
Thread: Inlet manifold gasket- rubber seals
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Default Inlet manifold gasket- rubber seals
    Hi guys
    Quick question, the rubber seals that sit on the block on the intake manifold, which way do they go on? The ones I got in the cars kit don't seem to fit over the block, too small in width, so they kind of stretch out when you push them down on to the block. Had everything back together and the car is still runnin like a tractor after getting cracked heads reco'd. Cheers
    Holden vt calais 5 litre
    Nov 2007
    make sure you have the right one for the series of your car as the series 1 inlet manifold is slightly different to the s2 also don't forget to use sealant on both corners when installing the rubber gaskets
    VT S2 Wagon
    Nov 2011
    SA
    theres a tab thing on one end of each one that has to sit sort of under the port for it to sit properly also make sure to use sealant
  1. Inlet manifold gasket
    By spud_22 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2011, 05:06 PM
  2. Head gasket or inlet manifold gasket? HELP!
    By CUR53VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-11-2011, 03:54 PM
  3. vs inlet manifold gasket set
    By sumpie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-10-2011, 09:47 AM
  4. Head Gasket? Inlet Manifold Gasket ? which one ?
    By Hydrobollox in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2010, 08:11 PM
  5. manifold gasket and dizzy seals?
    By vnstu in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2006, 01:24 AM
