Results 1 to 5 of 5
Thread: Reaaaaaaally rough idle
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Default Reaaaaaaally rough idle
    So with the help of some legends here, the car is now running and not stalling. As much. Problem is its idling really rough. I managed to reverse it out of the driveway, but in park, neutral, and all gears symptoms are the same. Ac on an it's still the same. Foot on the brake, same. Could the earth on the back of the head on the passengers side contribute to this? Had the heads redone and they came back painted. Stupidly didn't sand the spot back. Also, passenger side head, in between the front two injectors, in the cut out part of the intake manifold, there is a bold hole there with nothin in it. The bolt hole is in the head Could this cause a vacuum leak or wouldn't it go through the head walls. This car has me stumped.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Maybe pull each lead off the plug one by one and see if one of them doesn't make your idle any worse. Will help you determine if you have an electrical problem.
    If you determine it's on a certain cylinder, maybe swap the plug with another cylinder see if the problem moves. If so, new plugs.
    Swap two coil packs around and see if the problem moves. If so, new coil packs (all not just the 1)
    If it's still dropping that one cylinder, change your plugs and your leads.
    Probably your best bet.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    wrx884's Avatar
    wrx884 is online now WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    do a self diagnostic test and see if u can rule out a EGR fault.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    vr wagon
    Aug 2010
    vic
    S1 VT Wagon
    Apr 2005
    Gold Coast
    Faults that came back were 47 and 49, crank sensor signal. Rang Holden and they said this wouldn't cause the problems I'm having. Or explain why I'm using close to 1l of fuel per kilometer. Throttle body came of but has new gaskets, cleaned out and alla vacuum hoses back on at both ends
  1. VQ rough idle
    By simon0081 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2012, 06:44 PM
  2. Rough LS1 idle
    By anvlson1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2010, 06:00 PM
  3. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  4. Rough Idle
    By Flat_White in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-12-2008, 10:40 PM
  5. Rough idle when hot
    By Motorsport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2005, 01:31 PM
