Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By CHEETR
Thread: vt s 3.8 to 5 litre help
    vt ss
    Dec 2011
    penrith
    Default vt s 3.8 to 5 litre help
    hey guys i bought a vt commodore for 3 k it was originly a 1998 vt s supercharge and had a conversion to a 5 speed and 5litre engine
    the gauges on the car do not work but the fuel gauge engine was out of a 96 vs ute the owner who done it all said everything is there just needs to be wired up
    the question is this a big problem im not to smart with electrical i have asked around and get told different things 1 guy said needs all new wiring ect another says everything should go in very confused
    VT Series 1 V6
    Jan 2008
    Hi mate,
    For starters the car is illegal. You can't put an older engine into the VT in NSW, it won't comply with emissions/pollution standards and all that crap. Secondly, I take it the dude who put the motor in didn't change the wiring loom to suit? If not, this will cause some problems. Does the car run/drive? I'd be surprised if it did.
    Best bet is either an auto sparky, or find a loom from a 5L VT and swap the lot (including PCM). The other alternative though would be to grab a supercharged 6 and put it back to stock.
    VS GTS & VT XU6
    May 2011
    hes right unless it was from a series 3 ute that was the same year and month as the vt the engine conversion can be looked at illegal and again hes right you will need to find a engine loom and computer from a VT 5 litre and the bcm to match otherwise you will have to pay to get them linked if you do that it should all be plug and play mostly if it was from a vs series 2 or older you will need to get a maf and add that and remove the map sensor and block where it connected to the manifold or you could get it tuned with out the maf but will cost you heaps and thats if you can find some one that knows what there talking about.
    Good luck you may very well be better off selling it and starting again o and make sure you get a loom and computer to suit the 5 speed as well a auto one wont work
    vt ss
    Dec 2011
    penrith
    thanks for the feedback guys
    the guy who originally had the conversion done already had it blue slipped and regersted and at the rta they said nothing about it BUT the engine numbers match the papers but it still has the 3.8 capasity on the papers :$ i can get a blue slip through the guy that originaly did it and passed it he said everything was done and the rta have stuffed up so not to worried i can get around that
    the car starts and runs very good fuel gauge works but temp rpm and kph dont work and most of the lights on the dash are on and beebing ???
    so 1 where could i get the wiring loom i need iv looked around the net nothing for 5 litre vt manual or 2 if i take it to an electrician can he some how wire it up with out getting a new wiring loom ???
    and yes if its going to be a big hassel i will sell it
    VS GTS & VT XU6
    May 2011
    auto elec can do anything its more of just how much that will cost and sadly they will never quote on a job like that they will just say our hourly rate is $xx and we will just keep going till its done you could get a $200 bill you could get a $1000 bill you never know.
    You could try a few wreckers for a loom but the issue your going to have very very few people will sell just a loom and computer does if run a maf at the moment o and get the numbers sorted with the rta asap you could get into trouble if they some how found out.
    Is the car a series 1 or 2 ?
    VT feature car, WRX STI WAGON
    Aug 2006
    here is a couple reasons your motor wont work..
    VT 5ltr ECU runs the sequential injection, also has a MAF and the vt 5ltr motor is a roller cam motor with additional vaccum hoses..
    the motor you have put in is hydrolic, less vaccum hoses, no sequential injection and no MAF
    vt ss
    Dec 2011
    penrith
    the car is a series 1 1998 iv rang the original guy he just recons you gotta hook everything up i sent him a msg asking if its the old wiring loom or if he got the vt ss loom waiting for reply
    ok im not to switched on with this stuff can sombody tell me what a MAF is and what it does lol ?
    Aug 2006
    as i said, series 1 vt v8 had the roller motor with sequential injection and MAF
    the motor in your car is hydrolic, no sequential and no MAF, meaning not only will it not work properly but its also illegal.
    MAF is the air flow meter, stands for MASS AIR FLOW
    you need to know these things so we can help you
    - which ECU is the car running
    - Which LOOM is the car running
    you could have a couple issues here,
    if its a vt 5ltr loom on a vs 5ltr motor, you have an issue.
    if its a vs 5ltr loom and motor using a VT ecu, you have an issue
    if its a vs 5ltr loom, motor and ecu well then your still in strive with your RTA
    VS GTS & VT XU6
    May 2011
    what did he get the motor from thats the big question VS series 3 utes ran up till 2000 and ran the same motor used in the VT do a engine number check and find the aprox year of the motor thats a good place to start.
    This is a Maf Vy V8 commodore,LS1 Mass Air Flow Sensor ( maf sensor ) Vt,Vx,Vy, 5.7ltr | eBay
    it should be connected in the pipe work between the air box and throttle body it measures the incoming air speed and helps the engine calculate the amount of fuel needed and the pressure to use in the auto.
    Also what engine covers does it have the rounded vt style or the older vn-vs style ?
    No offence but the guy you got it off seems to be talking crap to you if it was the matter of pluging a few things in why didnt he do it ? hes not going to admit to doing dodgy stuff maybe the reason he sold it because he couldnt get it working right.
    VS GTS & VT XU6
    May 2011
    does the engine run a vgrove belt on the alternator or a ribbed belt ? if your not sure take a few pics and post them up
    Aug 2006
    easiest way to tell if its a hydrolic motor, is look and see if you have a maf, takes 2 seconds
    VS GTS & VT XU6
    May 2011
    doesnt mean the clown that sold it to him put the maf on it but yes it is if its there
    vt ss
    Dec 2011
    penrith
    thanks again guys for your help im getting closer to getting this fixed ok so the engine is out of a series 2 1996 vs ute they ran till 1998 and i have a 1998 s pac here are some engine bay pics
    VS GTS & VT XU6
    May 2011
    sadly my friend you have your self a series 1 or 2 vs motor there that looks like it sat in the open out of a car for a bit becasue there is alot of alloy oxidation on it no matter what the guy doing the blue slip said that engine is as has been said illegal for your car you will have to get a auto elec. to wire up the dash and stuff because a VT loom or computer wont work with it and no amount of pluging stuff in will make it work like the previous own says
  15. #15
    VS GTS & VT XU6
    May 2011
    you would be better off buying another car or buying a wrecked VT factory fitted with a V8 and putting all that in this and then selling the engine thats in it now
  16. #16
    Aug 2006
    mate, that motor is ultra illegal in that car.. good luck with it though
    dosnt matter about the year, needs to comply with emissions..
    meaning you would need to pull that motor down, rebuild with roller cam, add sequential injection and maf with a vt loom and ecu..
    to put it simply, it needs to come out and be replaced with a vt one + loom and ecu
  17. #17
    VS GTS & VT XU6
    May 2011
    o and that is some hell dodgy wiring going on around the battery and im guessing a dodgy earth on the inlet manifold there will be more than a few hours making that all work and to be cleaned up
  18. #18
    vt ss
    Dec 2011
    penrith
    hmm not sure what to do can an auto electricion still hook my gauges up with out the loom ??? car has been blue slipped and passed already
  19. #19
    VS GTS & VT XU6
    May 2011
    yeah he should be able to but like i said might cost $200 might cost $1200 wont know till hes done good luck with it
  20. #20
    vt ss
    Dec 2011
    penrith
    ok well thanks heaps guys for all your feed back learnt alot i love commodores and vt v8 has always been the car iv wanted since i was a kid and i really like this car and would like to keep it but if it turns out to be a big shit fight il sell it and get my money back or somthing thanks again guys
  21. #21
    vt ss
    Dec 2011
    penrith
    hey guys just n update have all the loom connected car is running good just 2 thins i need to Ask number 1 as iv explained this car was a vt s supercharge and had a sereis 2 vs 5.0 litre put in it but the engine does not have the air con generator so my question is i need to buy a vs generator but will my vt aircon lines fit onto it and will it work ???
    second question the car has cruise control but again doesnt work will i be able to get that working i just picked up a vs 5.0 cruise control thing for the engine bay will that work with the vt buttons ??
    any help would be great cheers
  1. 284 or 276 cam for 5 litre?
    By satinblackv8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-12-2011, 10:26 AM
  2. HSV VT 5 Litre vs Standard 5 Litre
    By Oken in forum General Discussion
    Last Post: 03-08-2009, 06:56 PM
  3. 6 litre or 5.7 litre conversion
    By kohan in forum LSx Development and Modification
    Last Post: 28-06-2009, 01:43 PM
  4. what oil for my 5 litre
    By franks v8 man ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 09:20 PM
  5. $1.40 a litre
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 05:58 PM
