Results 1 to 6 of 6
Thread: VT won't wind over
    VP S S2
    Dec 2011
    hobart
    Default VT won't wind over
    Hi All
    Got a huge problem with a mates vt, hopefully someone can help...
    Got a vt thats been sitting around for about 6 months now, and it don't turn over.
    When you turn the ignition on, all the dash lights come on, but fuel pump, blower fan, engine fan and everything else don't work.
    I've eliminated all the basics (fuses, relays, wiring), even replaced pcm, bcm and key.
    For some reason, self diagnosis fault ain't working by jumping the diagnosis plug.
    Any help would be great as it going to cost too much to get it towed into a workshop just to put it on the computer since i'm so far out of town...
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    After sitting around for 6 months there is a good chance that the battery is low on charge.
    MY RIDE
    VP S S2
    Dec 2011
    hobart
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by mick8308 View Post
    It still winds over by jumping the relay... batery's fine
    Not necessarily. Try starting it with jumper leads. Also, after six months the petrol in the tank will probably have gone off, so you will need to drain & refill with new petrol if it doesn't start once you fix the cranking problem.
    VX Executive S2
    May 2006
    Frankston South Vic
    when you bridge the diagnostic are you getting 12
    bcm and pcm and key must be linked with tech 2 or all from same donor car
    does red mode led stop flashing
    VX Equipe
    Dec 2011
    rockhampton
    same thing happend to my car but i only left it for a month because of my brakes. I tried to start it and it kept winding over and didnt start, all i did was get another battery and jump started it it started first go and alsobasically what black vx said new feul even if it will start i wouldnt want shit fuel like that in my car but gl anyway
LinkBacks (?)
  1. 08-02-2012, 10:33 AM
  2. 05-01-2012, 11:01 PM
  1. wind screen
    By 5.0l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2011, 01:47 PM
  2. vz wind noise
    By viss in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-05-2010, 04:49 PM
  3. Is it possible to wind back the K's?
    By -**wHiStLe**- in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-02-2010, 02:08 PM
  4. Wind Break
    By -ToM- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2009, 10:28 PM
  5. drag from wind for a ute
    By Conn in forum General
    Last Post: 09-08-2008, 07:53 PM
