hi guys,
iv just brought a vz monaro cv8z front bar complete with the monaro headlights and the parker/fog lights. i have a vx executive and am having trouble finding out how to wire up the fog lights and the parkers considering that my vx had the parkers in the headlights. any light on the subject would be great.
If you buy an SS headlight switch and a 5pin micro relay and install it in the labeled spot the wiring should all be there. You will need to join the wires to the dignified themselves as the plugs won't match up, but as far as I know there should be wiring good to go as they all share the same loom across all models.
i have had a look at my vx wires for my head lights and there is 6 pins in the terminal and on my monaro headlights i have 4 so would i be able to run a wire from the 2 pins to my parker lights below? and thn just run a fog light loom to a switch.. would that work?
