Results 1 to 9 of 9
Thread: Removing rear disc trouble ! help
    VX Lumina
    Nov 2010
    melbs
    Default Removing rear disc trouble ! help
    I'm trying to remove the rear brake rotars, and after severel attemps to hit them off with a hammer and mallet they still wont come off.
    the brake calaper is off and the handbrake is also off. any advice would be great! cheers
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Spray with wd-40 or the like an hit it harder!!!! It will come off.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    VX Lumina
    Nov 2010
    melbs
    It feels as though somthing is holding the disc on though. the disc can be moved and it only comes off a little bit then moves back to where it was. almost as if the handbrake is still on ??
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The handbrake shoes will be holding it on. Rotate the disc and pull it at the same time. You may have to back off the hand brake adjustment on the lever first as people will adjust them there and then the cable ends pulling the shoes on a bit, this jams the rotor.
    Visit my Facebook page
    99 VT Series 1 Wagon
    Nov 2010
    has it got mag wheels?....does it have hub adapters?......
    Never approach a goat from the front , a horse from the rear or a fool from any direction
    VX SS
    Jun 2005
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I agree with this. The shoe adjuster needs to be backed off. The disc probably has worn a lip inside and the shoes are getting caught in there.
    VX Lumina
    Nov 2010
    melbs
    ok so back off the hand brake a bit. you do that through one of the holes on the front of the rotor yeah ?.
    and nah it's got standard rims and no hub adapters.
    i actually disconnected the handbrake cable off the rotor completely. the rotor still wouldnt move
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes, rotate the rotor so that the largest hole is at the bottom and then using a screw driver, turn the adjuster through that. Can't remember which way it turns to back it off, but you will work it out once you start turning it. It is a wheel with teeth on it and it will either go up or down.
    VX Lumina
    Nov 2010
    melbs
    alright thanks for your help !
  1. trouble removing cam on 202!!!
    By vktorana in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-09-2011, 04:39 PM
  2. Lowering VT, Trouble removing rear springs!
    By Cúl-Báire in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-07-2010, 10:06 PM
  3. Fs: [vic] Vk Disc To Disc 3.23 Rear
    By synoptica in forum Parts And Other Items For Sale
    Last Post: 11-12-2007, 11:52 PM
  4. Having Trouble Removing Air Con Contorls HELP!!
    By Dan_8933 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2007, 06:31 PM
  5. having trouble with removing headunit
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 11:33 PM
