My rear power windows won't go up or down using any of the window switches. I just bought a new main power window switch too since the old one was ####ed. Can someone give me some advice on fixing this problem. My car is a 1999 Vt Series 1 Equipe if that helps at all.
It could be a broken wire in one of the rear door looms, in the rubber boot between the door and body, it happens a lot. This can affect the operation of the main switch.
MY RIDE
If the rear switches are stuffed, the main switches won't work either. Check them out with a multimeter.
Thanks for the advice guys. I'm gonna check it tommorow
