Results 1 to 9 of 9
Thread: Rear Door lock stuck/ wh caprice
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default Rear Door lock stuck/ wh caprice
    Help, my left rear door is stucked lock on wh caprice. When I press the remote I can here the motor working and can see the lock move a little but it does not open. I tried everything like dissconecting battery and open it but its stuck closed. I try to pull it up but does not budge. I opened the door handle from inside and can see two rods (one for the door handle and one for the lock) going to the back of the door. Any help will be appreciated. Also the door is closed and I cannot open the door panel because there ae screws on the side.
    vx v6 comodore
    Jan 2011
    sunshine coast
    Get in the car, Lock the car with the remote, And as u press the unlock button on the remote to unlock all the door's pull UP on the lock as it's unlocking...
    U must have a faulty actuator but doing the above will unlock it if u get the timing right.
    Stucked??...
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Stucked, bypassing the swear filter, he means ####ed?
    Visit my Facebook page
    Jul 2011
    saudi arabia
    Thanks for the tip I will try it. I have a honda crv never gave a lot of trouble.
    Jul 2011
    saudi arabia
    Now I have two doors stuck OMG. Now my passenger door is stuck also. I think something else wrong with my car. When I press the remote sometimes two doors open, sometimes one, sometimes three. Also my windows sometimes they open fast sometimes slow. Whenever I open a lock I hear a clicking noise from under the glove box in the passenger seat and the lights on the dashboard dim. Sometimes my cd player gets stuck, the buttons do not work. i think its somethin electrical. Any idea? I dissconected the battery and gonna leave it unplugged the whole night and lets see what happens in the morning.
    Jul 2011
    saudi arabia
    I was lucky. When I went to my car to reconnect my battery I found out that my driver side door will not unlock. I rotated the key but would not unlock. I could see it move a little but did not go up. I was stuck. The battery was disconnected so my remote did not work. Luckily I put my hand under the car and unscrewed the bonnet till it was lose. Then I took a hanger and slided it in the bonnet and made the wire connect to the battery and unlocked with my key. Now all three of my doors will not unlock, except the driver door. So much security put in the car. How do you turn it off.
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    My front passenger door once refused to unlock.
    I locked the car, then pressed and held the lock button again until the indicators flashed for 3 seconds, pressed unlock twice to unlock all the doors and voilą - doors all unlocked. Hasn't been a problem since.
    My car is a 2000 VTII Calais International
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    The lock pin doesn't go up when you open your car with the key and the battery is disconnected. I would be wondering if your car has been water damaged... Something is wrong with that wiring because generally Commodores are pretty good apart from things like door handles, lock actuators, window switches and window regulators working usually the wiring is pretty good but your problems seem too many to be all individual things failing.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Jul 2011
    saudi arabia
    Yup its my door lock actuators. by locking unlocking several times I manged to open three doors. My rear driver door still stuck. How I now its actuator is because I can see the button wiggle and door mechanism work. How expensive are the door actuator, I am going to replace them. Still have to open my rear door.
  1. Help! rear passenger door stuck in dead lock
    By darkclaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2011, 11:16 PM
  2. rear door stuck locked
    By kniever in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2011, 02:35 PM
  3. VU II Driver's Door Lock Button Stuck!
    By Peterld in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 07:42 AM
  4. VX deadlock stuck on rear passenger door
    By litchy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-08-2010, 11:23 PM
  5. Rear door Windows Child Lock
    By nabed4t in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-11-2008, 10:59 PM
