Results 1 to 9 of 9
Thread: Brake Caliper Pot Popped Out
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Default Brake Caliper Pot Popped Out
    Long story short... I removed my brake caliper to take a wheel hub off my car (my friend needed to borrow a decent one to pass the pits). As I am wrecking the car I had someone come and look at the engine to hear it running. As I am an idiot I started the car with my foot on the brake (habit I guess). Now I need to relocate this car to my grandparents place before I strip it so I was going to get a permit to drive it there.
    However due to my idiocy one of the pots on the caliper has popped out and I can seem to push it back in with my thumb. Anyone know a way to rectify this or should I just cut my losses and replace the entire caliper with a spare one from the shed. Only pain then is having the bleed the brakes and I'll also have to bin the set of front calipers from this car instead of potentially selling them.
    Any input would be appreciated I'd like to be able to get this car rolling again tomorrow if possible.
    Thanks
    Mick
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Why do you have to bin the front calipers? And you'll have to bleed the brakes either way if the piston came out. Assuming you mean piston by pot.
    EDIT: The pic wasn't there when I posted
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Mick1988's Avatar
    Apr 2008
    I tried to push it back in but it won't go. If I undo the bleed screw (i have a one man bleed kit that is a one way valve that goes onto the bleed nipple) and push it will it go back?
    Hangman's Avatar
    Jan 2010
    It should push back in.
    Mick1988's Avatar
    Apr 2008
    It doesn't as it is now so I'll try with the bleed screw open? It wriggles around then I touch it that's why I was thinking it had popped out completely or something
    pablo is offline Donating member
    Was a 1997 vt v6 wagon
    May 2006
    Crack open the bleed nipple and push it back with a 'G' clamp. Though now that the piston is out, it will be contaminated with dirt, so the whole unit should be dissmantled and re-assembled clean, to do the job correctly!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The dust boot that is on the caliper needs to be pulled out a bit and fitted over the base of the piston without it coming out of the caliper for the piston to go back in. The lip of the boot would be stopping it from pushing in.
    Visit my Facebook page
    Mick1988's Avatar
    Apr 2008
    Cheers for that mate, I'll give that a crack today. Maybe next time I won't be so stupid to apply the brakes when a caliper is loose..
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    when you push the pot back in place a block of wood or something to stop the other pot from popping out .
  1. brake caliper upgrades
    By GunnyVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-11-2009, 11:06 AM
  2. Hand Brake Button Popped Out?
    By You_Jealous in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2009, 10:37 PM
  3. Brake caliper movement
    By VL-VP-VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2008, 11:28 AM
  4. Brake caliper types
    By Longman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2008, 12:59 AM
  5. Brake Caliper Cover kit??
    By akcim13 in forum General
    Last Post: 09-03-2006, 04:30 PM
