Results 1 to 6 of 6
Thread: Over Heat
    1999 VT Acclaim
    Feb 2009
    ACT
    Default Over Heat
    Hi guys,
    My VT was over heating. I checked the radiator and it was very low. I took the time to flush out the radiator and place new coolant in. Now I seem to have lost the heater and have a drip coming from the engine side of the black tube on passengers side of car.
    How could I fix these issues?
    Thanks,
    Anthony
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    its called a heater tap valve very easy fix.
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    Jan 2008
    NSW
    Heater tap is on the drivers side just above the rail. Get someone to move the heater dial from hot to cold while you sus out the heater tap. If it doesnt move, move the mechanism buy hand a few times it may have gotten stuck. If that doesnt fix it, replace it (its only a $20 part).
    Im guessing the hose you described is the bottom radiator hose? Did you take this off during the flush? Make sure the hose clamp is tight. Sometimes when you fiddle around with an old hose it may get a crack/split as they aren't as flexible anymore. So replace that as well.
    Im hoping you bled the system? If not, do it after you fix the heater and leak.
    -(assuming you dont know how) Turn the heater on full and hot.
    -Ensure overflow is full.
    -Open radiator cap.
    -Turn car on.
    -Loosen bleed screw on thermostat housing.
    -Fill coolant in radiator as level drops.
    -When coolant starts to over flow from radiator cap thing replace cap.
    -When steady coolant starts to flow out of bleed screw tighten that up.
    -For the next few days, in the morning and when the engine is cold, top up coolant in radiator and overflow bottle.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    [QUOTE=ant142;2060906]Hi guys,
    Thanks,
    Anthony[/QUOTE
    I'm guessing he's talking about the air con drain tube. If so, heater core is shagged. Good luck.
    1999 VT Acclaim
    Feb 2009
    ACT
    My heater settled over the last two weeks. I left it home and found alternative transport during Xmas. I talked to a mechanic today and he said that I need to replace the thermostat. Would you it's know if there is somewhere I may be able to pick one up on Sunday??
    Thanks for your help.
    1999 VT Acclaim
    Feb 2009
    ACT
    The leak is coming from the black hose on the bottom passengers side i'll look at getting a replacement for that also.
  1. T5 Heat
    By wamboin23 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2010, 06:53 PM
  2. No Heat. VS
    By robert_buntine in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2006, 07:58 PM
  3. VR Heat
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 02:12 PM
  4. heat in vs v8
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2005, 02:08 PM
  5. 202 oil heat?
    By CAFA_TF in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-01-2005, 05:15 PM
