Results 1 to 7 of 7
Thread: Warning Light Commodore VT V6
    Commodore VT
    Jul 2011
    Default Warning Light Commodore VT V6
    Hi when driving on freeways or especially when the car gets over 80km/h this warning light comes on the dash, all temps are normal and the car doesn't loose any power. This has only started coming on after the head gasket was replaced. Any ideas to what this warning is, as its very alarming to be travelling at 100km/h and have this come on.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    Yeah thats the management light. You need to check what codes have been logged in the system.
    Checking error codes VT/VX
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    ffestival is offline Banned
    Ford WB Festiva
    Nov 2011
    Darwin
    maybe just have a look under the bonnet and make sure all the sensors are plugged in and check the oil and coolant.
    Quote Originally Posted by superchargedvs6 View Post
    well that was a helpful response...
    Commodore VT
    Jul 2011
    Thanks superchargedvs6, didn't work at first but worked it out. Turns out if was 63 (LH oxygen sensor (no signal)) so I disconnected the battery looked and checked the fuses mainly engine sensor. Put back in as its fine reconnected the battery, followed the same process and low and behold only got 12 (Satisfactory operation)
    see how that goes.
    Cheers guys
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by paulr22 View Post
    see how that goes.
    Cheers guys
    Oh ok good to hear that worked out If it happens again, then check that the oxygen sensor is plugged in properly. If it is then you might need to replace it. Its up to you but if it was my car I would replace both. Depends how much money you have to spend.
    Commodore VT
    Jul 2011
    Yeah thats what I'm going too do is replace them both. Good to know that when I'm on a freeway and if it comes on again I know exactly what it is.
    Best part is a simple .pdf and paper clip can diagnose the issue
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Haha yeah I know, easier and it doesn't cost you anything. And yeah at least you know what the problem is now so you wont have to worry about while driving.
  1. VE Commodore SS - Oil Warning Light
    By doons in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-11-2010, 05:59 AM
  2. Alternator Warning Light & ABS OFF Light
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2007, 10:10 PM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  4. VN commodore warning light
    By dug7000 in forum General
    Last Post: 06-10-2004, 02:36 PM
