Results 1 to 10 of 10
Thread: Oil Consumption
    VX Commodore Executive
    Jun 2011
    Central Coast
    Default Oil Consumption
    My 2002 VT Series II has recently started using oil at an alarming rate - about 1 litre every 1000 Kms.
    We have had the car for around six years, and it did not do this previously.
    We recently converted it to LPG, but this started just a little while before that, although I think the LPG has made it a bit worse.
    Any ideas on how to reduce the consumption?
    We do oil changes every 10,000 Kms (about every three months!).
    Cheers,
    JG
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Jun 2011
    Central Coast
    Sorry, I forgot to mention that there are no oil leaks - that was the first thing I checked for.
    vx v6 comodore
    Jan 2011
    sunshine coast
    What weight oil are u using?
    How many K's has your car got?
    Next oil change, Try a thicker oil, Also get some morie's oil stabiliser and put the full litre in.
    Using that much oil without leak's it can only be that your car is burning it, So a thicker oil + good additive could reduce the consumpion quiet a bit.
    Jun 2011
    Central Coast
    From memory I am using 15/w40 oil.
    The car has done about 180,000 Kms, 20,000 of it in the last six months.
    It is due for a service now, and I am planning on doing it while on Christmas leave.
    I will try the thicker oil and Morie's Oil Stabiliser.
    What thickness oil should I use?
    91 vn s
    Jun 2009
    Adelaide, SA
    20w50 is the most common thicker grade of oil used in these motors, try to stick to the same brand that you have previously been using,
    Otherwise i would reccomend 20w-60 penrite oil I just did the oil change in mine and the motor seems to rattle less *touch wood*
    Jun 2011
    Central Coast
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Yeah I found both my ecotecs burn about 1.5L per 10,000. but thats a lot more then me :S But Yes try a thicker oil, i use the Penrite 15-60 Extra 10, its great much quieter then 10-40, both have over 200k on them. Also once you have chosen a oil, stick with it.
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Do not use thicker oil,your engine will work harder,die sooner,if its burning oil will burn more quicker.Thick oil recomended for high klms older engines,not for oil burning engines.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by VTS5 View Post
    Lol. Thicker oil is for higher km engines.
  1. Oil Consumption
    By PeterVX2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2011, 07:34 PM
  2. VR Oil Consumption
    By Twisted in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2011, 03:48 PM
  3. VY V6 oil consumption!!!
    By oilburner681 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-08-2006, 09:35 PM
  4. GAS consumption
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2005, 02:55 PM
  5. Bad Oil Consumption
    By zoidberg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2003, 04:48 PM
