Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Like Tree5Likes
Thread: Yet another VT Rear Camber problem.
    VT Acclaim SII Wagon
    Dec 2011
    Yarrawonga, Victoria
    Default Yet another VT Rear Camber problem.
    Hi Guys,
    I just installed a camber kit on the rear of my VT Wagon.
    I've had it aligned by a pro and all is well..............on the left, the right is still out to buggery.
    He said it could need axle shortening or a new arm.
    My Question is this:
    Where can I get this checked and/or fixed? (Near Yarrawonga Victoria)
    What cost am I looking at?
    Cheers guys
    -Gh0stK1ll3r
    GSXR1000
    Apr 2010
    WA
    Dec 2011
    Thats what I'm after, the bloke that did the alignment told me that no one in Yarrawonga would no what to do with it.
    Even he had no idea how to fix it.
    Dec 2011
    I should also note that I only did the inner kit. Was told that doing both would bugger the diff and or axle.
    Cheers guys
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    Call around Albruy/Wodonga there will be someone there thats can fix it
    Dec 2011
    Killr6's Avatar
    Killr6 is offline on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    should spend some coin and get a vy/vz cradle. so you dont have a mega bad camber
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    Dec 2011
    Quote Originally Posted by DanLucas View Post
    VY/YZ Cradle?
    '99 VT
    Nov 2008
    south east melbourne
    I've heard from a number of tyre/suspension places that they're a waste of money and time, they don't do much in the long term. I was after a 4 point camber kit and they said don't bother. That's just what I heard from the pros
    Dec 2011
    Well there is no taking them out now. :/
    It's made a huge difference to the feel of the ride.
    Let's just say it was a damb site worse before I did the job.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    On a VT, a camber kit will only slow down your tyre wear not fix it. So you either have to live with it or do the VY craddle conversion.
    Tim Smtih's Avatar
    Tim Smtih is offline Sexy Man
    VXS1 Acclaim Family spec Limited Hardcore Edition
    Sep 2009
    Here.
    I had the same issue with the right side, the guy said he couldn't get it spot on. He didn't recommend anything besides trying a four point kit instead of a two.
    http://tinyurl.com/MetalisAwesome
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
    Albert Einstein
    Evoke VE HSV GTS 6.0 auto, XR6 turbo ute.
    Aug 2011
    Mount Gambier, SA
    Sounds like you need to go to someone who actually knows what they are doing.
    My daughters VT Clubby had camber kits fitted, and her tyre wear has been very flat since.
    JMP
    JMP is offline
    VT Calais
    Jun 2010
    I've got a camber kit on my series 1 calais with super lows in the rear and gas tank in the boot. 1 year on and got the alignment checked not long ago, it was almost perfect. The guy doing it was surprised he could get it so close with the height of the rear end and my rear tyres are still wearing even.
  15. #15
    ve sv6
    Aug 2010
    sounds like the x-member and or trailing arm is bent, if it wasnt you should be able to get both sides even or close to it.
  16. #16
    VT feature car, WRX STI WAGON
    Aug 2006
    sounds like you have a crack in the cradle, pretty common problem that i see weekly usually above the diff
  17. #17
    VS Stato l67
    Mar 2009
    Melb
    I took my IRS VS with camber kit to 4 places in 6 months and not one of them could do an alignment. They took my money and when I got the car back the wheels were at different angles even to the naked eye. I got all sorts of excuses like its impossible to get it perfect, near enough is good enough, chassis twisted, control arm bush isn't pressed in properly (which it clearly was) etc.
    Finally took it to a peddars who charged me a bit for an alignment but got it perfect and I haven't touched it for 2 years and its still sweet.
    Id say find someone capable of doing an decent alignment or willing to spend the time to get it right before throwing money replacing parts needlessly
  18. #18
    vn_v6's Avatar
    vn_v6 is offline Blumpkin
    87 vl limited edition
    Aug 2009
    victoria
    i have a mate with vz cradle and he still gets camber wear?? :S
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
  19. #19
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    Quote Originally Posted by vn_v6 View Post
    yeah you will still get camber wear, just not as bad as the vt's.
    how low has your mate gone?
  20. #20
    Dec 2011
    Thanks guys, I will try all these things, is it worth double checking the right rear alignment myself, to see if the tyre auto man was just a nit wit? I've got instructions that came with the kit on aligning the rear.
  21. #21
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    I heard & read the same thing to about getting a 4 point camber kit.
    Something to do with the diff or a tailshaft issue.
    2 point camber kit (inner i believe) is the best you can get.
    it won't eliminate camber wear but it will slow it down a lot.
    is this correct???
  22. #22
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by Shen Long View Post
    is this correct???
    Camber kit should have no effect whatsoever on diff or tailshaft for an IRS car.
    What I was told is 2 point gives some adjustability but 4 points gives more. So 4 points is better providing you can get someone to align it properly. It seems to be that very few people are any good at aligning these bad boys so they take your cash and blame the hardware
  23. #23
    WH Caprice 5.7L
    Sep 2011
    Roxby Downs
    Quote Originally Posted by monkeys437 View Post
    taken from the Nolathane website...
    http://www.nolathane.com.au/install_..._50-6138GB.pdf
    DO NOT DISCARD
    Keep these instructions in Glove Box
    Wheel alignment Instructions
    For I.R.S Camber and Toe Adjuster
    NB: All adjustments should be done at inner point only. Outer
    point should be set with crush tube set at 12 O’clock position as in
    Diagram 1 and not adjusted.
    Any adjustment of outer point may cause drive shaft and or
    differential failure.
  24. #24
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I almost did this myself. But my suspension guy told me to keep the extra cash and he will fit and supply the camber kit. Best thing i ever did it's pretty much as good as you can get it. But in all honesty you just need to find the right people who's job is solely suspension work.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  25. #25
    VS Stato l67
    Mar 2009
    Melb
    DO NOT DISCARD
    I think the drive shaft this is talking about are the axle shafts, (CV shafts, half shafts or whatever you want to call them) and NOT the tailshaft. The tailshaft can't be damaged by adjusting toe and camber because the diff is rigidly mounted to the cross memeber. And for the thing about only adjusting the inner bush only that sounds like a "cover our arse" statement to protect the product from being held responsible for any damage thats caused by a poor installation/adjustment. This wouldn't surprise me after seeing some of the clueless monkeys out there doing rear alignments. I work in the automotive aftermarket and the majority of the stuff that we sell for modified cars voids terms, conditions and warranty so we cant get sued for damages due to a poorly thought out backyard combo or some "performance" workshop who has a stuff up and tries to handball the blame. I cant see any risk in having an adjustable outer bush providing its aligned by someone who knows their stuff
  1. camber problem
    By clutch in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-04-2011, 09:37 AM
  2. VT Rear Camber Issues = FE2 Springs Require Camber Kit?
    By Puma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2010, 05:46 PM
  3. Which is the right rear camber kit???
    By holden_4aw_lyfe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2010, 10:03 PM
  4. Rear Camber Kit
    By PanthaVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2008, 11:02 AM
  5. how can i fix my camber problem
    By OLI-23Q in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2005, 01:57 AM
