Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By vx_commodore
Thread: how to disable door actuator
    5.7ltr gen III v8 325hp
    Jul 2011
    saudi arabia
    Default how to disable door actuator
    Well my door locks in wh caprice sometimes get stuck, except my driver door (it always open). I asked for a new actuator here and is 80 dollars per actuator. I was thinking to remove or disable the actuator so I can manually open/close lock (just like old days) without the fear of it getting stuck. What is the procedure. Also my car is close toy 300k kms, what engine oil should I put in the car. Thanks in advance.
    vx v6 comodore
    Jan 2011
    sunshine coast
    Just take the door trim off and unplug the wire harness off the acuator, Then it will be manual lock...
    Have you tried second hand?
    Oil, 20w50 should be fine, Or even Penrite 20w60 extra 10.
    Other than that, Penrite 40w70, But that's more for old kingswood's with 500k on the clock,Altho we have used it in a few of our older car's in the summer.350+k's
    I always use diffrent oil weight's as the weather change's, So example, 20w50 in summer or 15w40 in winter.
    So in you're case, Being that it is summer i'd go a 20w60.
    Jul 2011
    saudi arabia
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Why dont you get one from eBay,they r cheap enough or order one from here,,, AUS, Do not change the oil grade,thicker oil will make your already tired engine work even harder.
  1. [VIC] Vy door actuator
    By stooie in forum Swap / Wanted to Buy / Trade
    Last Post: 05-06-2010, 04:43 PM
  2. Door actuator
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-08-2008, 08:12 PM
  3. Door actuator - help!!
    By dbates in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2006, 01:29 PM
  4. replace door actuator
    By Graham Adams in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2006, 03:58 PM
  5. Door actuator......Need Help URGENTLY!!!!!
    By fruity in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-06-2006, 09:04 PM
