Results 1 to 3 of 3
Thread: ignition swith
    vx acclaim
    Sep 2011
    sydney
    Default ignition swith
    hody,,,when i turn the key over the key seems to feel loose and goes down all the way,,and car kicks over and it sounds like the starter stays on for a bit,,,,,,,and then i have no wipers is this the ignition swith and af so is it easy to replace ,,,cheers,,,,,
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    When you turn it to START does it spring back to ON when you let the key go? Or does it stay in the START position?
    If it stays on START then you will need to change over the inner most part of your steering column. Your ignition barrel will still be OK so swap it into the new column so your keys still match.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Mick1988 View Post
    Sorry, I have to disagree. The part that makes it spring back is the ignition switch. It happened to me once, key would not spring back so I changed the switch and that fixed it.
    MY RIDE
  1. VS V8 Auto Neutral Swith
    By runner8 in forum Electrical Wiring / Questions
    Last Post: 16-04-2010, 04:19 PM
  2. VZ swith L98 fuel regulator
    By monsteroz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-11-2009, 08:09 PM
  3. lights swith
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2008, 06:27 PM
  4. Ignition problem help needed, Ignition lead fallen out??
    By boourns in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2008, 05:04 PM
  5. VR Torque Convertor Swith
    By nolim8ts in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-03-2007, 08:53 PM
